Official tutorial cameras show uniform white
Important: Isaac Sim support
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX4090
  • Driver Version: 570.133.20
Topic Description
Isaaclab:main
Detailed Description
When I run official Isaac Lab tutorial scripts with ./isaaclab.sh -p scripts/tutorials/04_sensors/add_sensors_on_robot.py --enable_cameras and view the onboard camera (viewport or Camera.data.output[“rgb”]), the image is uniform white (uint8 RGB mean ≈ 235–255, no scene content).
front_cam:
Steps to Reproduce
  1. If I create a new camera in the GUI, the same scene then renders correctly in the viewport and in sensor output.Camera:
  2. If I turn off the lights, the screen will be completely black, and the objects in the environment are not rendered.front_cam:
  3. The same problem also occurs when I mount the camera onto my rigidbody; the camera view shows pure white.
Error Messages
(Camera @ ‘/World/envs/env_.*/Robot/base/front_cam’:
data types : [‘rgb’, ‘distance_to_image_plane’]
semantic filter : :
colorize semantic segm. : True
colorize instance segm. : True
colorize instance id segm.: True
update period (s): 0.1
shape : (480, 640)
number of sensors : 2
Received shape of rgb image: torch.Size([2, 480, 640, 3])
Received shape of depth image: torch.Size([2, 480, 640, 1])
Ray-caster @ ‘/World/envs/env_.*/Robot/base’:
view type : <class ‘omni.physics.tensors.impl.api.ArticulationView’>
update period (s) : 0.02
number of meshes : 1
number of rays/sensor: 187
total number of rays : 374
Received max height value: 3.814697265625e-06
Contact sensor @ ‘/World/envs/env_./Robot/._FOOT’:
view type : <class ‘omni.physics.tensors.impl.api.RigidBodyView’>
number of bodies : 4
body names : [‘LF_FOOT’, ‘LH_FOOT’, ‘RF_FOOT’, ‘RH_FOOT’]
Received max contact force of: 139.1256561279297
2026-05-27 08:50:46 [48,841ms] [Warning] [omni.usd] Warning (secondary thread): in GetInstanceIndices at line 2190 of /builds/omniverse/usd-ci/USD/pxr/usdImaging/usdImaging/pointInstancerAdapter.cpp – ProtoIndex 1 out of bounds (prototypes size = 1) for (/Visuals/ContactSensor, /Visuals/ContactSensor.proto1_mesh_id0)
2026-05-27 08:50:46 [48,841ms] [Warning] [omni.usd] Warning (secondary thread): in GetInstanceIndices at line 3256 of /builds/omniverse/usd-ci/USD/pxr/usdImaging/usdImaging/delegate.cpp – Empty InstanceIndices (/Visuals/ContactSensor, /Visuals/ContactSensor.proto1_mesh_id0))
I want to know what causes this situation and how I can get the camera to render the correct image.
Hi, The tutorial you run is an Isaac Lab tutorial, to get better help, please file an issue to Isaac Lab GitHub issues. I am closing this topic.
