• TLT Version: tao-toolkit:5.5.0-data-services
I am trying to run some offline augmentation. The current TAO documentation being completely outdated, I have been referring to: nvidia_tao_ds.
I’m getting an error with the translation augmentation. At the moment I am unable to specified a list with length > 1.
According to the code, translation should be a list of int
@dataclass
class TranslationConfig:
"""Translation configuration template."""
translate_x: List[int] = LIST_FIELD(arrList=[0], default_value=[0])
translate_y: List[int] = LIST_FIELD(arrList=[0], default_value=[0])
My configuration is therefore a list of ints
spatial_aug:
flip :
flip_vertical: false
flip_horizontal: true
translation:
translate_x: [0, 100, 200]
translate_y: [0, 100, 200]
But I am getting the following error:
Error executing job with overrides: []TypeError: float() argument must be a string or a real number, not 'DataNode'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/augment/scripts/generate.py", line 163, in main
run_augment(cfg)
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/core/decorators.py", line 82, in _func
raise e
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/core/decorators.py", line 51, in _func
runner(cfg, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/augment/scripts/generate.py", line 70, in run_augment
pipe = pipeline_dict[dataset_type]( File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/augment/pipeline/sharded_pipeline.py", line 276, in build_kitti_pipeline
pipe = sharded_kitti_pipeline(
File "/usr/local/lib/python3.10/dist-packages/nvidia/dali/pipeline.py", line 1958, in create_pipeline
_generate_graph(pipe, pipe_func, args, fn_kwargs)
File "/usr/local/lib/python3.10/dist-packages/nvidia/dali/pipeline.py", line 1809, in _generate_graph
pipe_outputs = func(*fn_args, **fn_kwargs)
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/augment/pipeline/sharded_pipeline.py", line 256, in sharded_kitti_pipeline
mt = spatial_transform(
File "/usr/local/lib/python3.10/dist-packages/nvidia_tao_ds/augment/pipeline/sharded_pipeline.py", line 65, in spatial_transform
offset = np.float32(
ValueError: setting an array element with a sequence.
The value returned from random_pick function is of type DataNode
def random_pick(values):
"""Randomly pick from values or range."""
if len(values) == 0:
value = 0
elif len(values) == 1:
value = values[0]
elif len(values) == 2:
value = dali.fn.random.uniform(range=tuple(values))
else:
value = dali.fn.random.uniform(values=list(values))
return value
Is that correct or is there a bug? is the Dali pipeline well implemented?
I am not familiar with the Dali library so I did not spend much time investigating.
