• How to reproduce the issue ?
What is the correct way to create augmentations of a custom dataset.
I have a dataset in COCO format and I convert it to tfrecords for training. Since the dataset is very small I want to add more augmentations for these images, so I was following the steps here offline_data_augmentation .
The command I use is: tao augment -a /workspace/dataset/specs_augment.txt -o /workspace/dataset/cherry/augmented/ -v -d /workspace/dataset/cherry/train
I run into the error: google.protobuf.text_format.ParseError: 2:3 : Message type "DatasetConfig" has no field named "data_sources".
What is the correct replacement for DatasetConfig, i.e. the correct way to specify the path to tfrecords? What is the difference between specifying the dataset using -d in the arg verses specifying it in the spec file as image_directory_path?
Is there a sample file for offline augmentation for maskrcnn which I could refer to?
Thank you for your reply @Morganh . I did check the jupyter notebook but I couldn’t find the examples about offline augmentation in these.
For offline augmentation I tried the spec file given here: running the augmenter tool but it just gives the output: 2022-05-06 13:59:45,110 [INFO] tlt.components.docker_handler.docker_handler: Stopping container. without generating any augmented images.
There is an option to augment_input_data: True in the spec file to augment while training, but is there a way to modify these augmentations like in the augmentation_config for FasterRCNN ?
Thank you for your reply @Morganh I found the example files for offline augmentation in cv_samples_v1.3.0 . From what I understand it needs data in kitti format, whereas the data I have is in coco or tfrecords format. So maybe offline augmentation fails because of that.
It would help me if I could do online augmentation instead since it is also supposed to give better results, what is the correct format to specify the augmentation_config specs?
I followed the example given in cv_samples_v1.3.0/unet/specs/unet_train_resnet_unet_isbi.txt which specifies it as: dataset_config { dataset: "custom" augment: False augmentation_config {
and I run into the error:
google.protobuf.text_format.ParseError: 42:1 : Message type “Experiment” has no field named “dataset_config”.
2022-05-10 10:27:19,681 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
If I follow the syntax example here cv_samples_v1.3.0/, : augmentation_config { output_width: 96 output_height: 48 output_channel:
I run into the error: google.protobuf.text_format.ParseError: 42:1 : Message type "Experiment" has no field named "augmentation_config". 2022-05-10 10:38:45,078 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I couldn’t find a specific syntax for online augmentation for maskrcnn. I am using the command from the maskrcnn examply jupyter notebook from the samples to train : tao mask_rcnn train -e $SPECS_DIR/specs_cherry_augment.txt \ -d $USER_EXPERIMENT_DIR/experiment_dir_unpruned_augmented\ -k $KEY \ --gpus 1
Thank you @Morganh . I have set this but how can I customize this? If I want to add something like how it is done in the file unet/specs/unet_train_resnet_isbi.txt for online training in maskrcnn :
