Offline update system
current system: JetPack 6.0 Jetson AGX Orin Series, Jetson Orin NX Series, Jetson Orin Nano Series [L4T 36.3]
target system:JetPack 6.2.1 Jetson AGX Orin Series, Jetson Orin NX Series, Jetson Orin Nano Series [L4T 36.4.4]
how to only update bootloader kernel ,not rootfs?
Trying nvidia-jetpack is successful, but it requires an Internet connection.The actual working environment does not have an Internet connection.
To upgrade the Jetson Orin Nano from JetPack 4.6 (L4T 32.6.1) to JetPack 6.2.1 (L4T 34.1), you can follow these steps:
  1. Check the current system: Your current system is JetPack 4.6 (L4T 32.6.1) on Jetson Orin Nano Series.
  2. Target system: You want to upgrade to JetPack 6.2.1 (L4T 34.1) on Jetson Orin Nano Series.
  3. Upgrade method: Since you have tried nvidia-jetpack and it requires an internet connection, you can use the same method to upgrade your system.
Comparison of JetPack versions:
  • JetPack 4.6 (L4T 32.6.1) is an older version, and upgrading to JetPack 6.2.1 (L4T 34.1) will provide you with the latest features, security patches, and performance improvements.
  • JetPack 6.2.1 (L4T 34.1) supports the same Jetson modules as JetPack 4.6 (L4T 32.6.1), including Jetson Orin Nano Series.
Upgrade steps:
  1. Connect your Linux host computer to the internet.
  2. Open a terminal window on your host computer and enter the command nvidia-jetpack.
  3. Follow the prompts to select the target system (JetPack 6.2.1) and the Jetson module (Jetson Orin Nano Series).
  4. The upgrade process will download the necessary packages and install them on your Jetson Orin Nano.
  5. Once the upgrade is complete, your system will be running JetPack 6.2.1 (L4T 34.1).
Note: Make sure to back up any important data on your Jetson Orin Nano before upgrading, as the upgrade process may erase all data on the device.
Comparison of Jetson modules:
  • Jetson AGX Orin Series, Jetson Orin NX Series, and Jetson Orin Nano Series are all supported by JetPack 6.2.1 (L4T 34.1).
  • The main differences between these modules are their memory configurations and performance capabilities.
  • Jetson Orin Nano Series is a more compact and power-efficient module compared to Jetson AGX Orin Series and Jetson Orin NX Series.
In summary, upgrading from JetPack 4.6 (L4T 32.6.1) to JetPack 6.2.1 (L4T 34.1) on Jetson Orin Nano Series will provide you with the latest features, security patches, and performance improvements. The upgrade process is straightforward using the nvidia-jetpack command, and you can expect improved performance and capabilities on your Jetson Orin Nano.
but the actual working environment does not have an Internet connection,can not use nvidia-jetpack, Is there a feasible solution to achieve offline upgrade?
Hello @gengqi_yz,
You could create a OTA payload and deploy it via USB.
Would something like that work for you ?
best regards,
Andrew
I will suggest to first clone the rootfs of the existing system. If anything goes wrong, then you can try again.
Btw, besides the OTA payload mentioned, you can “download now, install later” to a host PC. This could be something like a laptop, which is updated this way prior to moving to a location without networking.
run ota steps:
1.sudo -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 24GiB jetson-orin-nano-devkit R36-3
2.sudo ./nv_ota_start.sh ./ota_payload_package.tar.gz
question: It will overwrite the original rootfs, causing the private configuration and data in the original file system to be lost. How can we not lose the private configuration and data of the original rootfs?
You can clone first. Can you mount the NVMe on a different Linux computer? If so, then a simple dd command can give you an exact copy useful for recreating.
rsync is an option as well, although it differs in several ways. If you have sufficient storage, then rsync can be used locally as well as over ssh (and no Internet won’t matter if you have a second computer right there; either the USB virtual wired network would work, or a locally attached device such as a USB SATA drive).
Many parts of the flash directory’s content is used verbatim in creating the image to be flashed. Parts which might be edited are due to the flash target specification, and includes the kernel, device tree, and any boot config. You can later copy those over from a clone if you desire, but much of this can be preserved without issue by editing the “Linux_for_Tegra/rootfs/”. As an example, my ssh permissions, user accounts, ssh keys, host keys, bash aliases, so on, are in my “rootfs/”, and every flash has that right from the start.
Note that what really works best is that after you’ve installed a working system, and it is configured how you want, that a clone is a good idea because this can be used either directly during a flash or via copy into the “rootfs/” (direct use ignores “rootfs/” and is a bit-for-bit exact flash of your clone).
If your rootfs is on an NVMe, then it is far simpler to just mount it on another computer and use dd instead of cloning while it is on the Jetson. If you want dd information just ask.
