OGN - Read Prim Attributes: Dynamic Output(s)
How do I add dynamic outputs similar to this image from a Demo scene?
I think I am going to need a little more information to answer your questions. What do you mean by “dynamic” outputs ? Can you explain what you are trying to achieve and I can answer that.
How does one create any outputs on this node?
The assumption is that the Attribute parameter is used to build the outputs based on the Attribute pattern, but that doesn’t work, in my test.
No matter what I tried, I could not get any outputs on this node.
