OLED 1.3" display problem interfacing with jetson nano
I am trying to interface 1.3" OLED display with jetson nano. But I am facing a display problem with that. As u check the below-attached image, u can find that only the top 10% display working, the remaining all just showing black screen. I have tried running all example programs given by the adafruit_python_SSD1306 library. but always 90% of display shows a blank screen.
example code
import time
import Adafruit_GPIO.SPI as SPI
import Adafruit_SSD1306
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
import subprocess
Raspberry Pi pin configuration:
RST = None # on the PiOLED this pin isnt used
Note the following are only used with SPI:
DC = 23
SPI_PORT = 0
SPI_DEVICE = 0
Beaglebone Black pin configuration:
RST = ‘P9_12’
DC = ‘P9_15’
SPI_PORT = 1
SPI_DEVICE = 0
128x32 display with hardware I2C:
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST)
128x64 display with hardware I2C:
disp = Adafruit_SSD1306.SSD1306_128_64(rst=RST)
Note you can change the I2C address by passing an i2c_address parameter like:
disp = Adafruit_SSD1306.SSD1306_128_64(rst=RST, i2c_address=0x3C)
Alternatively you can specify an explicit I2C bus number, for example
with the 128x32 display you would use:
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST, i2c_bus=2)
128x32 display with hardware SPI:
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST, dc=DC, spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE, max_speed_hz=8000000))
128x64 display with hardware SPI:
disp = Adafruit_SSD1306.SSD1306_128_64(rst=RST, dc=DC, spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE, max_speed_hz=8000000))
Alternatively you can specify a software SPI implementation by providing
digital GPIO pin numbers for all the required display pins. For example
on a Raspberry Pi with the 128x32 display you might use:
disp = Adafruit_SSD1306.SSD1306_128_32(rst=RST, dc=DC, sclk=18, din=25, cs=22)
Initialize library.
disp.begin()
Clear display.
disp.clear()
disp.display()
Create blank image for drawing.
Make sure to create image with mode ‘1’ for 1-bit color.
width = disp.width
height = disp.height
image = Image.new(‘1’, (width, height))
Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
Draw a black filled box to clear the image.
draw.rectangle((0,0,width,height), outline=0, fill=0)
Draw some shapes.
First define some constants to allow easy resizing of shapes.
padding = -2
top = padding
bottom = height-padding
Move left to right keeping track of the current x position for drawing shapes.
x = 0
Load default font.
font = ImageFont.load_default()
Alternatively load a TTF font. Make sure the .ttf font file is in the same directory as the python script!
Some other nice fonts to try: Bitmap, pixel, screen fonts, small fonts, userbar | dafont.com
font = ImageFont.truetype(‘Minecraftia.ttf’, 8)
while True:
# Draw a black filled box to clear the image.
# Shell scripts for system monitoring from here : https://unix.stackexchange.com/questions/119126/command-to-display-memory-usage-disk-usage-and-cpu-load
cmd = "hostname -I | cut -d\' \' -f1"
IP = subprocess.check_output(cmd, shell = True )
cmd = "top -bn1 | grep load | awk '{printf \"CPU Load: %.2f\", $(NF-2)}'"
CPU = subprocess.check_output(cmd, shell = True )
cmd = "free -m | awk 'NR==2{printf \"Mem: %s/%sMB %.2f%%\", $3,$2,$3*100/$2 }'"
MemUsage = subprocess.check_output(cmd, shell = True )
cmd = "df -h | awk '$NF==\"/\"{printf \"Disk: %d/%dGB %s\", $3,$2,$5}'"
Disk = subprocess.check_output(cmd, shell = True )
# Write two lines of text.
draw.text((x, top),       "IP: " + str(IP),  font=font, fill=255)
draw.text((x, top+8),     str(CPU), font=font, fill=255)
draw.text((x, top+16),    str(MemUsage),  font=font, fill=255)
draw.text((x, top+25),    str(Disk),  font=font, fill=255)
# Display image.
disp.image(image)
disp.display()
time.sleep(.1)
What kind of interface is this panel using?
i2c
Sorry that it is not official supported panel interface. I will let other users to share experience.
