Good Day,
May I know if the Jetson Nano 2GB is compatible with the JetBot AI Kit? I am having an issue where the OLED is not showing the IP address. It might be because I’m using a 2GB model instead of the 4GB model.
Good Day,
Hi there @Anonymou5 and welcome to the NVIDIA developer forums!
From the available documentation there is no indication that the JetBot setup would not work with a Nano.
To better help you with the issue of the IP not showing up, I refer you to our dedicated Jetson Nano forums, I am sure you will find help here!
Thank you!
Nano 2GB should also work, but for Jetbot related issue, please report a bug by creating an issue at Jetbot github. Thanks
Fixed the OLED issue. Had to flash an older image on the jetson nano. v0.4.3 didn’t work but v0.4.2 worked.
