My model always over bright, even i have all pbr material map and texture, the reason is omn not support 3dmax PRB material—> roughness map
it support diffuse map, normal map, but not support roughness map…
please fix it.
please fix it.
If you required all maps to go through to omniverse from 3dsmax , atm the best I have found that works is using MDL and select OmniPBR from the drop down. Hope that helps for now.
I follow your advise to use MDL in max and I got nothing, even dont see a MDL export, so disappoint…
@sinsin54duck
Banana001.max (1.6 MB)
Banana tex.zip (4.9 MB)
I upload a sample file done in 3dsmax2021 for your reference.
Setup
Export settings
Results in Omniverse
wo!!thanks you for your reply so quick, but u miss the bpr mapping, can you upload it? so much thanks!
