Omni.datastore error
I’m running isaac sim with python standalone.
The error related to DerivedDataCache is keep showing up, which I could not find the root cause.
2026-03-26T17:32:58Z [651ms] [Error] [omni.datastore] Failed to acquire exclusive lock to data store (256>=256)
2026-03-26T17:32:58Z [651ms] [Error] [omni.datastore] Failed to create local file data store at '/home/kzl/Projects/isaacsim/kit/cache/DerivedDataCache'
This is the command I’m running from headless server:
`./python.sh my_folder/execute.py --headless “$@”`
# In executor.py, I'm running:
from isaacsim import SimulationApp
simulation_app = SimulationApp({
        "headless":          args.headless,
        "limit_cpu_threads": 16,
This is a file-lock contention issue in omni.datastore’s DerivedDataCache (used by PhysX collision cooking). The (256>=256) means 256 concurrent processes already hold locks on the shared cache directory.
Same root cause as this earlier thread — the limit was raised from 64 to 256 in newer versions, but you’re exceeding even the new limit.
Workarounds:
  1. Disable UJITSO PhysX cooking (eliminates the cache that causes lock contention):
   ./python.sh my_folder/execute.py --headless --/physics/cooking/ujitsoCollisionCooking=false "$@"
  1. Isolate cache directories per process so they don’t share locks:
   export OMNI_LOCALCACHE_PATH="/tmp/isaacsim_cache_$$"
   ./python.sh my_folder/execute.py --headless "$@"
  1. If neither helps, could you share:
  • How many concurrent processes you’re running?
  • Whether this is on a Slurm cluster or a single machine?
  • Your GPU model and driver version?
This will help us determine whether the lock limit should be made configurable or removed entirely for headless/batch workloads.
