I tried to load the “omni.isaac.conveyor.ui” extension, but it shows an error loading. I would appreciate it if you could help me to load the extension.
“Failed to solve extension dependency.”
Welcome to the community!
I didn’t encounter the issue in version 4.2.0. Could you please share the detailed steps to reproduce it?
Thank you for your response.
When I install the “omni.isaac.conveyor.ui” extension in Isaac Sim, it doesn’t appear under either the Tools menu or the Create → Isaac menu, which makes me think it might be located somewhere else. I’ve tried installing it on two different computers, but I encountered the same issue.
I’ve attached some screenshots for reference. Could there be any specific steps I need to follow before installing the “omni.isaac.conveyor.ui” extension? Any guidance would be greatly appreciated.
I could not replicate the issue. Is it still a problem for you? If so, which method did you use to install Isaac Sim?
I had the same Issue (missing dependencies) and had to switch to 4.5 to use the conveyors.
