It appears only a dark gray box is rendered within a widget instead of plot lines. I confirmed the plot is active as the mouse event callbacks trigger. Should this code display a correct plot?
I have attached the following code and screenshot below.
def test(self, one=None, two=None, three=None, four=None):
print("Released",one,two,three,four)
print("Show Plot!", omni.client.get_version())
self._window = omni.ui.Window("Data Acquisition", width=650, height=450)
with self._window.frame:
self.plot = omni.ui.Plot(omni.ui.Type.LINE, valueList=[(1,1),(2,2),(3,4)], mouse_released_fn = test)
self.plot.visible = True
self.plot.enabled = True
self.plot.title = "Test"
Can we get some more information on this? There is not a lot here to work with. Can we have your whole script and exactly what you are trying to do. You are trying to draw a line in the “UI” ?
I created a basic Omniverse extension (for the purpose of this post). The Extension.py code is below. When the extension is loaded a widget pops up (as expected) and loads the plot (dark gray) as click events do work when the window is clicked. No lines are plotted though.
The only other information I could find on “omni.ui.Plot” other than the main Omniverse auto generated API docs was this post: What is the input data type required by omni.ui.Plot?
This post shows plots that looks like this and is what I expect Omniverse plots to look like:
Extension.py
import omni
class PlotWidget(omni.ext.IExt):
def on_startup(self, ext_id):
init .py
from .extension import *
Let me see if I can find someone to help you.
Thanks for your help.
My problem actually got solved by the Omniverse Kit folks. Posting answer here as well to wrap up discussion.
omni.ui.Type.LINE
is a 3d line within a plot and omni.ui.Type.LINE2D is the actual normal 2d line plot.
You must specify a style color or plot will appear as it was not drawn
Set data using set_xy_data
and ignore valueList
self.plot = omni.ui.Plot(omni.ui.Type.LINE2D,
mouse_released_fn = test,
style={"color": omni.ui.color.white})
self.plot.set_xy_data([(1,1),(2,2),(3,4)])
Original answer: [QUESTION]: omni.ui.Plot does not seem to render correctly? · Issue #46 · NVIDIA-Omniverse/kit-app-template · GitHub
Great, that is wonderful to hear !
system
Closed
February 6, 2025, 8:31pm
7
