Omni_usd_resolver pxr-20_08 version does not exist
I’m building a custom connector and need the resolver library so that linked parts get automatically pulled from Nucleus when I load a file. According to the doc page (https://docs.omniverse.nvidia.com/kit/docs/usd_resolver/latest/index.html) there is a “pxr-20_08” flavor of the library, which is exactly what I need because we get that USD version as part of the environment.
Starting from the Connect Sample, I modify target-deps-packman.xml to include this:
<dependency name="omni_usd_resolver" linkPath="../_build/target-deps/omni_usd_resolver">
    <package name="omni_usd_resolver.pxr-20_08.nopy.${platform}" version="1.35.0" />
  </dependency>
Running repo.bat build gives me this error:
ERROR    An error occured while pulling packman dependencies for                         main.py:387
                             `C:/Users/AR3S/AppData/Local/ov/pkg/connectsample-203.1.0/deps/targe
                             t-deps.packman.xml`:
                             Package not found on specified remote servers! (name:
                             omni_usd_resolver.pxr-20_08.nopy.windows-x86_64, version: 1.35.0)
I tried a bunch of different version numbers for the same flavor, but none of them worked.
Can you help me?
Hello @k.lesiak , Thanks for reporting the issue. It seems an error in the doc - I will talk to the team and update the doc.
Following are the pxr no-py versions
  • pxr-22_11-ar2.nopy
  • pxr-23_05.nopy
  • pxr-23_08.nopy
Following are the 20.08 versions
  • nv-20_08.nopy
  • nv-20_08-utf8.py37
  • nv-20_08.py27
  • nv-20_08.py37
  • nv-20_08.py39
and 20.08 no-py version
  • nv-20_08.nopy
other pxr versions
  • pxr-21_08.py37
  • pxr-21_08.py39
  • pxr-21_11.py37
  • pxr-21_11.py39
  • pxr-22_05b-ar2.py37
  • pxr-22_08-ar2.py39
  • pxr-22_08-ar2.py310
  • pxr-22_11-ar2.py39
  • pxr-23_02.py39
  • pxr-23_02.py310
  • pxr-23_05.py310
  • pxr-23_08.py310
Does any of them fit your needs? If you do need pxr-20_08.nopy I will see if the team can build one.
Please let me know if you have more questions,
Wayne
Thanks for your response. :)
What I’m trying to do is to use the resolver library from within our Unity application (runtime, not only editor), and we’re using this package for USD import: USD Experimental Package for Unity | USD | 3.0.0-exp.5
They bundle 20.08 per their docs, so I’d need the resolver library compiled against that? I suppose the nv variant is not going to be binary-compatible with upstream USD, right?
FWIW, I tried using the nv variant even, but ran into plugin loading errors (something about a missing symbol, but didn’t really debug deeply).
If you could build a pxr-20_08.nopy variant for x64 Windows, that would be very helpful.
