OmniGeoSceneIndex example is not built
I’m trying to build an scene index example OmniGeoSceneIndex in OpenUSD-plugin-samples/src/hydra-plugins at main · NVIDIA-Omniverse/OpenUSD-plugin-samples · GitHub
However, the latest version doesn’t seem to build it at all even though there’re still source code.
Was it deprecated? If not, could you tell me how to build it please?
My environment is Ubuntu.
Thank you.
Hi there and thanks for the post. The issue is that this code base is very old. It is based on kit 106. So that means, either you need kit 106 to run it correctly, or you can try to run it on the latest kit 110 but it might not run or compile without errors.
The issus is that we do not even publish kit 106 anymore. You could try kit 107
What version of kit are you using?
I’m using kit 110.
Ok understood. Sadly, some of these really old repos are no longer going to work. We are now looking into this, to see what can be saved, and what cannot. If it does not build with 110, I am afraid the only other thing you could try it to go back to kit 107, before we remove it.
Sure. Thank you for replying.
