Omniisaacgymenvs
Hello everyone. I have been trying to implement my Robot UR10 within Omniisaacgymenvs. I always get the error with the end effector.
I don’t know how to achieve this, but this might help:
Thanks for sharing. I added the robot according to the principle from this repository. Could it be that I should first initialise the ROS environment and then run my algorithm with the robot?
I don’t think ROS has anything to do with the problem at this point. Maybe the problem is the way you create the USD. Check this out:
Thank you
Thanks, that helped to solve the problem :)
