Revit don’t want to load the omniverse connector, It used to work a few month ago but i can’t make it work right now.
I tried to uninstall and reinstall Revit, omniverse and the connector without success. I have the same error on my two computers. (i have an edu licence). Is there something to do to make it work? Maybe it s the licence or maybe an hidden file to reset? I don’t know…
I tried today with a different computer and a pro version of revit and still the same error.
Any luck on this issue? I’m having the same problem on Revit 2020.2.4.
This has happened before, when the user has a Windows localization that uses the comma instead of a period for decimal numbers. This should be correct in current versions of the Omniverse Revit Connector.
A fix is now in the works. Should be available within the month.
