Hello
just now got my omniverse enterprise license activated . i just got the entitlement certificate alone through mail no instructions were available for the cloud simulation setup . I need to setup a cloud setup for synthetic dataset generation and validation. kindly help with supporting docs , procedure to setup the account . Thanks in advance .
Hi there welcome to the forum. Actually, if you’ve just got your enterprise license, you’re better off filing enterprise tickets with your portal. That is the fastest way to get enterprise support.
Having said that I can start you off in the right direction. If you’re looking to do SDG, you need to use Isaac Sim 5.0. You can download it here.
The only account you may need is your NGC developers account. But it is not required. Go to www.ngc.nvidia.com. There you can download Omniverse Kit sdk and Nucleus Enterprise, if you need it.
If you are setting up in the cloud, just make sure you use our official AMIs. There are images for each major platform. AWS, Azure etc.
regarding cloud setup how to use the nvidia cloud platform (NVIDIA OVE) server to host the omniverse in server
That is not something that is automatic with being Enterprise. If you are interested in setting up a cloud system, you can build your own with a popular system from Amazon or Microsoft or you can contact your Nvidia Enterprise support about building a cloud solution with us at Nvidia.
I have nvidia OV cloud server instance running how to connect my omniverse sdk to the server that is running so that i can use the server for processing
You should contact your ENTERPRISE level support with a ticket
