Omniverse extension - Python scripting component
Hi everyone,
I installed Aerial Omniverse 1.1, and it’s working well. However, I’d like to deploy RU and UE using Python scripting instead of the GUI - it would make things much more efficient.
I came across the Omniverse Extension - Python scripting component (Python Scripting Component — Omniverse Extensions), but I couldn’t get it to work with AODT.
A couple of questions:
  • Is the Omniverse Extension compatible with AODT?
  • If yes, is there a guide for installing it? I couldn’t find the “Extension” menu in AODT.
I would appreciate any insights. Thanks!
Regards,
Omniverse extensions are not supported in AODT 1.2.
Thanks for the confirmation.
Hi Kpasad,
As a follow-up question, can RU and UE be deployed programmatically?
@seung.jang1
While they could be deployed programmatically, full support is lagging. We will add a better support in 1.3. What is your hardware and what is your use case? Perhaps we can recommend an alternative approach.
