Omniverse Houdini Connector release v102.3
We are pleased to announce our next update to the Omniverse Houdini Connector which includes some improvements to the user experience and bugs fixes.
Release Notes
Added
- Added Custom Relative Path Outputprocessor. Better support exporting relative path to Omniverse Nucleus.
Improved
Updated to Client Library 2.24.0 and USD Resolver 1.20.0
Optimized Omni Loader, Omni Validator, Omni Lights to improve performance
Removed inputs from Omni Frustum SOP
Live Sync LOP now sets the last modified prim when in pull mode.
Omniverse Connection dialog now works with
omniverse://
prefix. -
Houdini Connector FS plugin supports Omniverse checkpoint syntax now
The user right clicks the file string and enables checkpoint syntax. Then, they scroll through their checkpoints, reviewing changes to their model.
Fixed
Prevent mdl properties being converted to relative path or absolute path
Updated Omni EditMdl. Better handle of
info:mdl:sourceAsset:subIdentifier
attribute -
Omni Loader preserves expressions in file path mode now
Fixed an issue Connection Panel showing disconnected servers
Deprecated
- Removed object_omni_hdaConverter.hda
Please read the Houdini Connector Documentation.
Thank you for checking out the Omniverse Houdini Connector!
