RTX Lidar has noise built into the configuration parameters.
[azimuth,elevation]ErrorMean: error profile average in degrees for sensor azimuth/elevation position
[azimuth,elevation]ErrorStd: error profile standard deviation in degrees for sensor azimuth/elevation position
There is also a setting on the point cloud generating nodes to add an accuracy error to all points equally.
