Omniverse Kit Remote Client - Mac OS X
I was wondering if someone already got the Remote Client to work on Mac without installing Ubuntu/Windows directly, but using some other techniques?
I tried using it inside a virtual machine in VirtualBox (running Ubuntu 18.04), however I ran into some typical OpenGL incompatibility-problems of VirtualBox (Version mismatch of Host and Guest), which probably can’t be solved:
I-!$> [2020-11-02 13:33:38,988]=14:33:38= INFO [BifrostClient: Scheduler] {0E7FC700} - Successfully set TLS with value 0x1425200
I-!$> [2020-11-02 13:33:38,988]=14:33:38= INFO [BifrostClient: Scheduler] {0DFFB700} - Successfully set TLS with value 0x1425200
I-!$> [2020-11-02 13:33:38,988]=14:33:38= INFO [BifrostClient: Scheduler] {0D7FA700} - Successfully set TLS with value 0x1425200
I-!$> [2020-11-02 13:33:38,988]=14:33:38= INFO [BifrostClient: Scheduler] {0EFFD700} - Successfully set TLS with value 0x1425200
I-!$> [2020-11-02 13:33:39,003]=14:33:39= DEBUG [BifrostClient: Interface] {2F37D200} - nvbCreateClient( 0x15f4950 )
[2020-11-02 13:33:39,012]=14:33:39= ERROR [SDLGraphicsContext] {2F37D200} - GERONIMO_ERROR 0xC008000B GERONIMO_SDLWINDOW_CREATE_OGL_CONTEXT: SDL initWindowGL: Unable to create OpenGL Context.
[2020-11-02 13:33:39,012]=14:33:39= ERROR [SDLGraphicsContext] {2F37D200} - SDL Error : Could not create GL context: BadValue (integer parameter out of range for operation)
[2020-11-02 13:33:39,012]=14:33:39= ERROR [SDLGraphicsContext] {2F37D200} - Error Line : 528
[2020-11-02 13:33:39,012]=14:33:39= ERROR [GWindowManager] {2F37D200} - Unable to initialize SDLGraphicsContext!
[2020-11-02 13:33:39,012]=14:33:39= ERROR [RemoteGridApp] {2F37D200} - STARTUP: FAIL: Unable to initialize GWindowManager!
[2020-11-02 13:33:39,012]=14:33:39= ERROR [OV-Kit-Remote: main] {2F37D200} - STARTUP: FAIL: Configure Failed! Exiting.
Installed Version GuestOS: OpenGL version string: 3.1 Mesa 20.0.8
Installed Version HostOS: OpenGL version string: 2.1 INTEL-14.7.8 (can’t be updated, since Apple abandoned it)
As a direct question to the Nvidia-devs: Is a Mac-client planned in the future?
Hi Micha3l,
Supporting Mac-client is on the roadmap, but not in the next release.
Kindly,
Liila
Hi Liila,
Is there any ETA for that? I can’t find it in the PRM: Trello
no, unfortunately we still don’t have a confirm date for supporting mac.
