Omniverse Kit unit tests pass but set fails
Something strange is going on with the unit tests in my extension. The tests all pass but then the run fails. I stripped it down to 1 basic test that passes. And the set still fails . I have attached the log.
kit_20230803_165236.log (152.5 KB)
Any help is appreciated.
@anon24640076 out of curiosity, doesn’t seem like you are using the latest version of Code. have you tried getting the latest Kit and Code to see whether that helps?
p.s. here is a full list of the updates in 2023.1.1
We finally determined that the params used to force the tests to run on CPU on the pipeline server were incorrect.
