Dear Nvidia,
I can not login at omniverse launcher. I guess SSL cert. issue.
Is there any command line option to ignore SSL cert ?
ex) vscode : code --ignore-certificate-errors
by the way I did proxy setting on the command line (–proxy-server:…).
11:51:45.387 › Using proxy server 168.219.61.252:8080 for the main process.
11:51:45.476 › Failed to get GDPR, retrying in 2.5 seconds…
11:51:47.979 › Using proxy server 168.219.61.252:8080 for the main process.
11:51:48.066 › Failed to get GDPR, retrying in 2.5 seconds…
11:51:50.569 › Using proxy server 168.219.61.252:8080 for the main process.
11:51:50.657 › FetchError: request to https://messages.launcher.omniverse.nvidia.com/en/gdpr.json failed, reason: unable to verify the first certificate
at ClientRequest. (/tmp/.mount_omniveWDif93/resources/app.asar/dist/main.js:38:27499)
at ClientRequest.emit (events.js:315:20)
at TLSSocket.socketErrorListener (_http_client.js:426:9)
at TLSSocket.emit (events.js:315:20)
at emitErrorNT (internal/streams/destroy.js:92:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
at processTicksAndRejections (internal/process/task_queues.js:84:21)
11:51:50.657 › Error occurred in handler for ‘data-sharing-load-gdpr’: FetchError: request to https://messages.launcher.omniverse.nvidia.com/en/gdpr.json failed, reason: unable to verify the first certificate
