Omniverse menu doesn't show up in ARCHICAD
I have installed the ARCHICAD connector, the View app and a local Nucleus server, but I don’t see the Omniverse menu in ARCHICAD. I have ARCHICAD 24 build 5000. What should I do?
Hello @leroystreetstudio. We sometimes run into this issue. usually uninstalling, rebooting, and then re-installing the connector fixes this issue. Please go ahead and try this and report back. Thanks!
Hi @FViloria I was running into the same problem and followed your instructions and did not get any results. I there anything else I can do or any of the processes changed within this time? Cheers!
