Omniverse Streaming Client to server behind CGNAT
Has anyone found a solution to exposing an Omniverse server (I’m running Isaac Sim) through a CGNAT?
I understand that on the server I need to make these ports accessible:
  • The following ports need to be whitelisted: TCP/UDP 47995:48012, TCP/UDP 49000:49007, and TCP 49100.
Which I can’t really do because it’s behind a CGNAT. I have an ngrok tunnel for ssh, but the free tier doesn’t support multiple tunnels to the same IP for different ports.
Has anyone found a solution, or is there an NVIDIA sponsored one? (I could imagine an NVIDIA hosted reverse tunnel to help with this situation).
Cheers,
Ashis
You would need to host your server on a 3rd party solution that is easily accessible via the web. AWS, Google Cloud etc.
