hi guys, i downloaded nvidia omniverse launcher. im trying to download View but when the download is over its says:
Error occurred during installation of View: Command failed: “C:\Users\MAHSUM KARATAŞ\AppData\Local\ov\pkg\view-2022.1.0\omni.view.warmup.bat”
2022-04-16 22:56:39 [4,358ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/c:/users/mahsum%20karata%C5%9E/appdata/local/ov/pkg/view-2022.1.0/kit/mdl/rtx/iray/omni_light.mdl(1,1): C100 “mdl” expected
2022-04-16 22:56:39 [4,359ms] [Error] [carb.scenerenderer-iray.plugin] Import Error (4003): The module “::omni_light” was not found or failed to compile.
2022-04-16 22:56:39 [4,359ms] [Error] [carb.scenerenderer-iray.plugin] Import Error (4006): file:/c:/users/mahsum%20karata%C5%9E/appdata/local/ov/pkg/view-2022.1.0/kit/mdl/rtx/iray/omni_light.mdl(1,1): C100 “mdl” expected
2022-04-16 22:56:39 [4,359ms] [Error] [carb.scenerenderer-iray.plugin] Failed to import module ‘omni_light.mdl’.
2022-04-16 22:56:39 [4,359ms] [Error] [carb.scenerenderer-iray.plugin] Failed to import default modules.
2022-04-16 22:56:40 [5,270ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: file:/c:/users/mahsum%20karata%C5%9E/appdata/local/ov/pkg/view-2022.1.0/kit/mdl/rtx/Default.mdl(1,1): C100 “mdl” expected
2022-04-16 22:56:40 [5,271ms] [Error] [rtx.neuraylib.plugin] Compiler Core: file:/c:/users/mahsum%20karata%C5%9E/appdata/local/ov/pkg/view-2022.1.0/kit/mdl/rtx/Default.mdl(1,1): C100 “mdl” expected
2022-04-16 22:56:40 [5,271ms] [Error] [rtx.neuraylib.plugin] Failed to resolve overloads. The MdlModule ‘mdl::ZD8Default_2Emdl’ is not loaded.
2022-04-16 22:56:41 [5,753ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2022-04-16 22:56:57 [22,174ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2022-04-16 22:56:57 [22,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 14028 thread 13460
2022-04-16 22:56:57 [22,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 13460 backtrace follows:
2022-04-16 22:56:57 [22,442ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: carb.scenerenderer-rtx.plugin.dll!+0x73e51
2022-04-16 22:56:57 [22,442ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: carb.scenerenderer-rtx.plugin.dll!+0x74b69
2022-04-16 22:56:57 [22,442ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: carb.scenerenderer-rtx.plugin.dll!+0x6b9ce
2022-04-16 22:56:57 [22,442ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: carb.scenerenderer-rtx.plugin.dll!carbOnPluginShutdown+0x19eb1
2022-04-16 22:56:57 [22,443ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: omni.hydra.rtx.plugin.dll!+0x2fb7
2022-04-16 22:56:57 [22,443ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: omni.usd.dll!omni::usd::UsdManager::advanceAllSyncScopes+0x5ff
2022-04-16 22:56:57 [22,443ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: omni.usd.dll!omni::usd::UsdManager::attachAllHydraEngines+0x23
2022-04-16 22:56:57 [22,444ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: omni.ext-viewport_window.plugin.dll!+0x82342
2022-04-16 22:56:57 [22,444ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: omni.ext.plugin.dll!carbOnPluginShutdown+0x21a78
2022-04-16 22:56:57 [22,444ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: omni.ext.plugin.dll!carbOnPluginShutdown+0x1e424
2022-04-16 22:56:57 [22,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: omni.ext.plugin.dll!carbOnPluginShutdown+0x14a2e
2022-04-16 22:56:57 [22,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: omni.ext.plugin.dll!carbOnPluginShutdown+0x38b5d
2022-04-16 22:56:57 [22,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: omni.ext.plugin.dll!carbOnPluginShutdown+0x36eb4
2022-04-16 22:56:57 [22,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: omni.ext.plugin.dll!carbOnPluginShutdown+0x3e845
2022-04-16 22:56:57 [22,446ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: omni.kit.app.plugin.dll!+0x11e39
2022-04-16 22:56:57 [22,446ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: omni.kit.app.plugin.dll!+0xd765
2022-04-16 22:56:57 [22,446ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: omni.kit.app.plugin.dll!+0x46417
2022-04-16 22:56:57 [22,447ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: kit.exe!+0x371e
2022-04-16 22:56:57 [22,447ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: kit.exe!+0x431e
2022-04-16 22:56:57 [22,447ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: kit.exe!+0x28804
2022-04-16 22:56:57 [22,447ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: KERNEL32.DLL!BaseThreadInitThunk+0x14
2022-04-16 22:56:57 [22,447ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: ntdll.dll!RtlUserThreadStart+0x21
i hope u guys help me. plus i downloaded audio2face but when i click launch, it doesent start.
