If I run the Python script in the omniverse apps(Code, Create, IsaacSim) for the first time, it runs without any problem, but from the second time, an “Invalid arguments” error appears and no matter how I change the code, the same error keeps repeating. Even code that was previously executed well will show an same error. Can you solve it?
Hi @tdain721. I believe this is related to a known issue. We are tracking it internally as OM-48118. For now, check here for a possible workaround using carb.log_info()
: Calling on_update gives OSError:Errno22 Invalid argument
