OMP error
Could anyone help me to understand why the call of the intrinsic RANDOM_NUMBER within a PARALLEL DO directive in some cases it returns values larger than 1?
Here it follows the test code I made to show the problem.
      program test
      implicit none
      real*8   e_r
      integer*4 nps,i,j
      write(*,*) 'Number of tests'
      read(*,*) nps
      i=0
c$OMP parallel do private(e_r) reduction(+:i)
      do j=1,nps
         call random_number(e_r)
         if(e_r.gt.1.0d0)then
            write(*,*) e_r
            i=i+1
         endif
      end do
c$OMP end parallel do
      write(*,*) i
      end
the above code was compiled as follows
pgfortran test.f -mp -o test
Here below you can find the output
valerio@giusti-145 ~/Documents $ ./test
 Number of tests
1000
    1.539883970671497
    1.476670404429072
    1.412861223654971
            3
Thanks in advance for any suggestion (…and forgive me if I did something stupid :-) ).
The above Fortran code compiled with the Intel Fortran Compiler through the following command:
ifort test.f -openmp -o test
does not return any random number larger than 1.
 Number of tests
1000000
           0
Hi Valerio,
I don’t think our Randon_number’s default seed generator is thread safe and might be the root of the problem. I added a problem report (TPR#19454) to see what our engineers can do.
I was able to work around the problem by explicitly setting the seed.
% cat rand.F90
      program test
      use omp_lib
      implicit none
      real*8   e_r
      integer*4 nps,i,j, thid, seed(32)
      read(*,*) nps
      seed=123
      call random_seed(put=seed)
      i=0
c$OMP parallel do private(j,e_r) reduction(+:i)
      do j=1,nps
         e_r = 0.0d0
            write(*,*) e_r
            i=i+1
         endif
      end do
      write(*,*) i
      end
% pgf90 rand.F90 -Mfixed -mp; a.out
 Number of tests
10000
            0
  • Mat
Hi Mat,
thanks for your answer. I will use your trick to workaround the problem.
Valerio
Valerio,
TPR 19454 has been fixed as of the 13.9 release.
thanks,
dave
