$gst-launch-1.0 -ve rtsp://172.16.1.56/av0_0 ! rtph264depay ! h264parse ! omxh264dec ! fakesink
Setting pipeline to PAUSED …
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://172.16.1.56/av0_0
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: use-pipeline-clock = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: drop-on-latency = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: buffer-mode = Slave receiver to sender clock
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 5000000000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtcp
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad2: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_1811609324_96: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)4d0020, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AIJWoFACBkA==,aO48gA==”, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_1811609324_96: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)4d0020, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AIJWoFACBkA==,aO48gA==”, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d0020ffe1000a674d002095a81400819001000468ee3c80
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)014d0020ffe1000a674d002095a81400819001000468ee3c80
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)4d0020, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AIJWoFACBkA==,aO48gA==”, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_1811609324_96.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)4d0020, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AIJWoFACBkA==,aO48gA==”, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_1811609324_96.GstProxyPad:proxypad3: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, profile-level-id=(string)4d0020, packetization-mode=(string)1, sprop-parameter-sets=(string)“Z00AIJWoFACBkA==,aO48gA==”, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)1024, parsed=(boolean)true
/GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)1024, parsed=(boolean)true
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 5107: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 584: BeginSequence 1280x1024, bVPR = 0
TVMR: cbBeginSequence: 826: DecodeBuffers = 5
TVMR: cbBeginSequence: 850: Display Resolution : (1280x1024)
TVMR: cbBeginSequence: 851: Display Aspect Ratio : (1280x1024)
TVMR: cbBeginSequence: 1015: SurfaceLayout = 3
TVMR: cbBeginSequence: 1045: NumOfSurfaces = 9, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1
Allocating new output: 1280x1024 (x 11), ThumbnailMode = 0
/GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1280, height=(int)1024, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1280, height=(int)1024, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, framerate=(fraction)0/1
