**Status:** ready to submit. Post to the NVIDIA Developer Forums
> (GPU Computing / CUDA category):
> https://forums.developer.nvidia.com/
> Read the forum’s “read this first” first:
> »»»»»»»»»» If you have a problem, PLEASE read this first ««««««««««
## Summary
On a Blackwell `sm_120` GPU (RTX PRO 500 Blackwell Laptop) with CUDA 13.0
toolkit and driver 581.15 (Windows), a fully **bounds-checked, race-free**
CUDA kernel crashes **non-deterministically** during execution.
- The kernel uses **no shared memory**, **no `__syncthreads`**, and has **fully
independent threads** — there is no possible application-level race or OOB.
- The crash surfaces either as `cudaErrorIllegalAddress (700)` /
`cudaErrorUnknown (999)` reported by a subsequent `cudaDeviceSynchronize` /
`cudaLaunchKernel` / `cudaFree`, **or as a host-side segfault (exit 139)**
inside the driver/runtime.
- `compute-sanitizer --tool memcheck` reports **zero** memory diagnostics
(no “out of bounds”, no “unaddressable access”) — it only observes the
downstream `(700)` API errors on a dead context. The context is faulted by
something below the instrumentation layer.
- The crash point is non-deterministic across runs (iteration 1, 12, 18, or a
hard segfault, or no crash at all) for the **same binary, same input**.
This is reproducible with a single 92-line `.cu` file and a one-line compile.
## Environment
| Item | Value |
| GPU | NVIDIA RTX PRO 500 Blackwell Generation Laptop GPU |
| Compute capability | `sm_120` |
| VRAM | 6113 MB |
| Driver | 581.15 (R580 U3, Windows / WDDM) |
| CUDA Toolkit | 13.0 (`nvcc` release 13.0, V13.0.88, build `cuda_13.0.r13.0/compiler.36424714_0`) |
| `nvidia-smi` CUDA Version | 13.0 |
| VBIOS | 98.07.1c.40.31 |
| GPU part | 2DB9-925-A1 |
| OS | Windows 11 Enterprise 10.0.22621.1848 (x64) |
| Host compiler | MSVC 19.44 (VS 2022 BuildTools 17.14) |
| Build | `nvcc -O3 -arch=sm_120 naive_only.cu -o naive_only.exe -lcudart` |
No driver/toolkit mismatch (`nvidia-smi` reports CUDA 13.0, matching the
installed toolkit).
## Reproducer
Single file, `naive_only.cu`. It launches a trivial direct-convolution kernel
on a `1×64×128×128 → 128×3×3, stride 1, pad 1` convolution (output
`1×128×128×128`) 20 times back-to-back, with a `cudaDeviceSynchronize()` after
each launch. All four buffers are `cudaMalloc`'d and zeroed. Inputs are zero
(the crash is independent of input values).
```cuda
// naive_only.cu
// Minimal isolator: launch ONLY the naive direct-conv kernel on the “large”
// conv shape, 20 times back-to-back with a sync after each. No im2col, no
// sgemm, no tiled, no shared memory, no inter-thread communication whatsoever.
// Goal: determine whether the non-deterministic crash is reproducible with the
// simplest possible fully-bounds-checked, race-free kernel. If it crashes here,
// the defect is below the application (GPU/driver), not in the conv kernels.
include <cuda_runtime.h>
struct Param {
int N, C, H, W, K, KH, KW, sh, sw, ph, pw, dh, dw, groups;
int out_h() const { return (H + 2\*ph - dh\*(KH-1) - 1)/sh + 1; }
int out_w() const { return (W + 2\*pw - dw\*(KW-1) - 1)/sw + 1; }
constexpr int BLOCK = 256;
template
_global_ void naive_kernel(const float* _restrict_ x,
const float\* \__restrict_\_ w,
const float\* \__restrict_\_ bias,
float\* \__restrict_\_ y,
Param p, int OH, int OW) {
const int nk = blockIdx.x;
const int oidx = blockIdx.y \* B + threadIdx.x;
const int OHOW = OH \* OW;
if (oidx >= OHOW) return;
const int n = nk / p.K, k = nk % p.K;
const int oh = oidx / OW, ow = oidx % OW;
const int icpg = p.C / p.groups, ocpg = p.K / p.groups;
const int g = k / ocpg;
float acc = bias ? bias\[k\] : 0.0f;
for (int c = 0; c < icpg; ++c) {
const int ic = g \* icpg + c;
const float\* wbase = w + (k \* icpg + c) \* p.KH \* p.KW;
for (int kh = 0; kh < p.KH; ++kh) {
const int ih = oh \* p.sh - p.ph + kh \* p.dh;
if (ih < 0 || ih >= p.H) continue;
for (int kw = 0; kw < p.KW; ++kw) {
const int iw = ow \* p.sw - p.pw + kw \* p.dw;
if (iw < 0 || iw >= p.W) continue;
acc += x\[((n \* p.C + ic) \* p.H + ih) \* p.W + iw\] \*
wbase\[kh \* p.KW + kw\];
y\[((n \* p.K + k) \* OH + oh) \* OW + ow\] = acc;
define CK(call) do { cudaError_t _e=(call); if(_e!=cudaSuccess){ \
fprintf(stderr," iter %d FAILED: %s (%d)\\n", iter, cudaGetErrorString(\_e),(int)\_e); \\
goto done; } } while(0)
int main() {
Param p{1, 64, 128, 128, 128, 3, 3, 1,1, 1,1, 1,1, 1};
const int OH = p.out_h(), OW = p.out_w();
const size_t x_sz = (size_t)p.N\*p.C\*p.H\*p.W;
const size_t w_sz = (size_t)p.K\*(p.C/p.groups)\*p.KH\*p.KW;
const size_t y_sz = (size_t)p.N\*p.K\*OH\*OW;
cudaDeviceProp prop{}; cudaGetDeviceProperties(&prop, 0);
printf("GPU: %s sm\_%d%d OH=%d OW=%d iters=20\\n", prop.name, prop.major, prop.minor, OH, OW);
printf("grid=(%d,%d) block=%d x=%zu w=%zu y=%zu floats\\n",
p.N\*p.K, (OH\*OW+BLOCK-1)/BLOCK, BLOCK, x_sz, w_sz, y_sz);
float \*dx=nullptr,\*dw=nullptr,\*db=nullptr,\*dy=nullptr;
if(cudaMalloc(&dx,x_sz\*4)||cudaMalloc(&dw,w_sz\*4)||cudaMalloc(&db,p.K\*4)||cudaMalloc(&dy,y_sz\*4)){
fprintf(stderr,"cudaMalloc failed\\n"); return 1;
cudaMemset(dx,0,x_sz\*4); cudaMemset(dw,0,w_sz\*4); cudaMemset(db,0,p.K\*4); cudaMemset(dy,0,y_sz\*4);
dim3 grid(p.N\*p.K, (OH\*OW+BLOCK-1)/BLOCK);
int crashed = -1;
int iter = 0;
for (iter = 0; iter < 20; ++iter) {
naive_kernel<BLOCK><<<grid, BLOCK>>>(dx, dw, db, dy, p, OH, OW);
CK(cudaDeviceSynchronize());
CK(cudaGetLastError());
printf(" iter %2d OK\\n", iter);
printf("ALL 20 iters OK\\n");
crashed = -1;
done:
if (crashed >= 0 || iter < 20) {
printf("CRASHED at iter %d (kernel launched fine but sync reported fault)\\n", iter);
cudaFree(dx); cudaFree(dw); cudaFree(db); cudaFree(dy);
return 0;
### Build & run
naive_only.exe
Launch configuration: `grid=(128,64)`, `block=256` → 8192 blocks / 2,097,152
threads. Buffer sizes: `x=1,048,576`, `w=73,728`, `y=2,097,152` floats (all
zero-initialized). Each iteration’s kernel does ~1.2 GFMA and runs in ~0.02 ms
(measured separately) — well within any timeout.
## Observed behavior
Five consecutive runs of the **same binary, same input**:
| Run | Result | Exit code |
| 1 | All 20 iterations OK | 0 |
| 2 | Host segfault — process killed by OS before any buffered output flushed | 139 |
| 3 | `iter 12 FAILED: an illegal memory access was encountered (700)` | 0 |
| 4 | `iter 18 FAILED: an illegal memory access was encountered (700)` | 0 |
| 5 | All 20 iterations OK | 0 |
**3 of 5 runs crashed**, at different iterations (12, 18, or a hard segfault
with no iteration printed). The crash point is non-deterministic.
Representative raw output (run 3; stderr is unbuffered so the `FAILED` line
appears ahead of the buffered stdout):
GPU: NVIDIA RTX PRO 500 Blackwell Generation Laptop GPU sm_120 OH=128 OW=128 iters=20
grid=(128,64) block=256 x=1048576 w=73728 y=2097152 floats
iter 0 OK
iter 1 OK
iter 11 OK
CRASHED at iter 12 (kernel launched fine but sync reported fault)
The “kernel launched fine but sync reported fault” message is printed by the
reproducer’s own logic: `naive_kernel<<<…>>>()` returned `cudaSuccess`, but
the immediately following `cudaDeviceSynchronize()` returned `700`. The kernel
launch is accepted, then the GPU faults during execution.
## compute-sanitizer result (the key evidence)
compute-sanitizer --tool memcheck ./naive_only.exe
memcheck reports **zero application-level memory violations** — no
“Unaddressable access”, no “Out of bounds access”, no “Heap corruption”. It
only observes the downstream `(700)` errors propagating through the dead
context:
========= COMPUTE-SANITIZER
========= Program hit cudaErrorIllegalAddress (error 700) due to "an illegal
========= memory access was encountered" on CUDA API call to cudaLaunchKernel.
========= Saved host backtrace up to driver entry point at error
========= Host Frame: cuProfilerStop [0x7ffae7ebc355] in nvcuda64.dll
========= Host Frame: _cudaGetProcAddress [0x7ffb5dac8ff7] in nvcudart_hybrid64.dll
iter 1 FAILED: an illegal memory access was encountered (700)
========= Program hit cudaErrorIllegalAddress (error 700) … on CUDA API call to cudaDeviceSynchronize.
========= Program hit cudaErrorIllegalAddress (error 700) … on CUDA API call to cudaFree. (×4)
(Under memcheck it crashed at iteration 1 — again non-deterministic vs. the
bare runs at 12/18.) If the fault were an application-level out-of-bounds
access, memcheck would print the precise offending address and source line.
**It does not.** The context is killed by something memcheck cannot attribute
to any kernel memory access.
## Expected behavior
A fully bounds-checked kernel with no shared memory, no inter-thread
communication, and no `__syncthreads` must execute **deterministically** on
every launch. The same kernel + same input must not crash on some launches and
succeed on others. If a kernel genuinely faults, `compute-sanitizer memcheck`
must report the offending access.
## Actual behavior
- The kernel crashes non-deterministically (3/5 runs), at varying iterations.
- The fault surfaces as `cudaErrorIllegalAddress (700)` on a subsequent API
call, or as a host-side segfault (exit 139) inside the driver.
- `compute-sanitizer memcheck` reports **no** application memory violation —
only the downstream `(700)` errors on the dead context.
- The context is unrecoverable without process exit (`cudaDeviceReset` not
attempted; subsequent `cudaFree` calls all return 700).
## Why this is not an application bug
1. **No shared state.** Each thread computes one independent output element.
No `_shared_`, no `__syncthreads`, no atomics. There is no possible
data race.
2. **All accesses are bounds-checked.** Every `x[…]`, `w[…]`, `y[…]`,
`bias[…]` index is guarded (input coordinates checked against `H`/`W`;
output index derived from `n<K`, `k<K`, `oh<OH`, `ow<OW`). The launch grid
is sized exactly to the output. (Verified by hand against the `1×64×128×128
→ 128×128×128` shape.)
3. **memcheck confirms zero memory violations.** If there were an OOB, memcheck
would name the address and line.
4. **Non-determinism.** A deterministic application OOB would crash on the
*same* iteration every run. Here the crash iter varies (1 / 12 / 18 / segfault
/ none) across identical runs — impossible for a deterministic logic bug,
consistent with a driver/GPU execution fault.
5. **Same input every run.** Buffers are zero-filled and never mutated between
the 20 launches (the kernel writes `=` not `+=`). Every launch is
byte-for-byte identical, yet some fault and some don’t.
## What would help (asks)
- Confirmation of whether this is a known sm_120 / CUDA 13.0 / R580 driver
issue and whether a fixed driver build is available (R585 beta or later R580
branch).
- Whether downgrading the toolkit to CUDA 12.8 (also sm_120-capable) is known
to avoid the fault.
## Appendix: `nvidia-smi -q` (excerpt)
Timestamp : Thu Nov 5 11:03:51 2026
Driver Version : 581.15
CUDA Version : 13.0
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA RTX PRO 500 Blackwell Generation Laptop GPU
Product Brand : NVIDIA RTX
Product Architecture : Blackwell
Driver Model
Current : WDDM
Pending : WDDM
GPU UUID : GPU-f0864938-0351-b394-c453-8a0e4af86f42
VBIOS Version : 98.07.1c.40.31
GPU Part Number : 2DB9-925-A1
Full `nvidia-smi -q` output available on request.
## Files in this directory
- `naive_only.cu` — the reproducer (single file).
- `build.bat` — Windows build helper (activates MSVC + nvcc).
- `raw_run_{1..5}.log` — raw output of the 5 consecutive runs cited above.
- `memcheck.log` — full `compute-sanitizer --tool memcheck` output.
- `smi-q.txt` — full `nvidia-smi -q` output.
