On a MSX-6036 switch, how do I set the date on the switch?
The command reference manual suggests using the set clock command, however that only allows me to set the time and not the date.
It is the command clock set
See below:
switch (config) # clock set ?
switch (config) # clock set 12:00:00 ?
Set the time but leave the date unchanged
mti-mar-sx01 [standalone: master] (config) # clock set 12:00:00 2015/07/27 ?
mti-mar-sx01 [standalone: master] (config) # clock set 12/00/00 2015/07/27
Check this also
HowTo Enable NTP on Mellanox Switches https://community.mellanox.com/s/article/howto-enable-ntp-on-mellanox-switches
