On AGX Orin, does the DOL-HDR support VC mode to identify long&short exposure frames?
From your Jetson guide document I saw DOL-HDR uses LI(Line information) to identify long&short exposure rows. As we know from standard MIPI protocol there is another common way which is using different VC values in DI of PH to identify the long&short exposure rows, and my question is does AGX Orin or other Jetson SOCs support this VC mode?
hello bing.yan,
no, DOL-HDR in VC mode is not supported.
Hi Jerry,
Thanks for the reply. Our sensor does not use LI(line information) to identify long&short exposure rows, while we’re using different DT value in PH to identify different kind of rows and we do not have LI pixels, Does your Orin platform support this kind of method to identify long&short exposure rows? If not, any way to let it support this method?
Bing Yan
hello bing.yan,
please refer to Example Digital Overlap WDR Exposure Frame (3840×2160).
software side it uses LI (line information) code to select effective area only.
Thanks a lot, @JerryChang
