Just a quick question here. Has anyone written up an on-card OSS licensed Malloc/free routine for the GPU?
This library could be built using cudaMalloc to initially fill a pool of memory on the video card, then doll it out to threads/blocks on request. I might find myself needing to write a library that does this in the near-future and I was wondering if anyone else has gone down this path as well.
Also a question for Nvidia: Is an on-card memory allocation library forthcoming in a future release of CUDA? I don’t want to wind up duplicating work that is going to be released as part of CUDA in the future.
What is the purpose of re-implementing cudaMalloc?
I suspect that the currently limitation where device pointers cannot be passed between threads would make it difficult to implement a library like that.
I don’t think it can be done in CUDA 1.0 without having hard partitions in the memory between multiprocessors. In 1.1 it should be able to be done with an atomic-operation protected stack.
For 1.0, having hard partitions between multiprocessors is not that bad for the things we are working on as we can predict the max memory used by a block, just not a thread.
Eventually it will need atomic operations, but that is for the long-term.
My original posting was more about figuring out if this kind of thing is planned to be released with the next version of CUDA so I do not reinvent the wheel…
I planed to write this some time ago, but for some reason never had the time to look into this. I still have some problems at hand that would benefit from such a library, so I am very interested (and will probably write a library in the near future if no one else will do it).
If you are interested we may work together on this…
