Hi
tegra234-p3701-0000-p3737-0000.dts
Top level DTS file for CVM:P3701-0000 and CVB:P3737-0000.
Copyright (c) 2021-2023, NVIDIA CORPORATION. All rights reserved.
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; version 2 of the License.
This program is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
more details.tegra234-p3737-0000-a04.dtsi
/dts-v1/;
include “tegra234-p3701-0000-prod.dtsi”
include “cvm/tegra234-p3701-0000.dtsi”
include “cvb/tegra234-p3737-0000-a04.dtsi”
include “tegra234-power-tree-p3701-0000-p3737-0000.dtsi”
include “tegra234-dcb-p3701-0000-a02-p3737-0000-a01.dtsi”
include <tegra234-soc/mods-simple-bus.dtsi>
include “cvb/tegra234-p3737-camera-modules.dtsi”
include <t234-common-cvb/tegra234-pwm.dtsi>
include <t234-common-cvm/tegra234-cpuidle.dtsi>
include <t234-common-cvm/tegra234-thermal.dtsi>
include <t234-common-cvm/tegra234-thermal-cooling.dtsi>
include <t234-common-cvm/tegra234-thermal-userspace-alert.dtsi>
include <tegra234-soc/tegra234-soc-hwpm.dtsi>
nvidia,dtsfilename = FILE ;
nvidia,dtbbuildtime = DATE , TIME ;
compatible = "nvidia,p3737-0000+p3701-0000", "nvidia,p3701-0000", "nvidia,tegra234", "nvidia,tegra23x";
model = "Jetson AGX Orin Developer Kit";
nvsciipc-kernel {
compatible = "nvidia,nvsciipc";
status = "okay";
firmware {
android {
compatible = "android,firmware";
first_stage_delay = "1";
system_root_blkdev = "/dev/mmcblk0p1";
fstab {
compatible = "android,fstab";
vendor {
compatible = "android,vendor";
dev = "/dev/block/platform/3460000.sdhci/by-name/vendor";
type = "ext4";
mnt_flags = "ro,noatime";
fsmgr_flags = "wait";
display@13800000 {
status = "okay";
dce@d800000 {
status = "okay";
bpmp {
i2c {
tegra_tmp451: temp-sensor@4c {
vdd-supply = <&p3737_vdd_1v8_sys>;
ext {
shutdown-limit = <107>;
vrs11_1@20 {
compatible = "nvidia,vrs11";
reg = <0x20>;
rail-name-loopA = "GPU";
rail-name-loopB = "CPU";
status = "okay";
vrs11_2@22 {
reg = <0x22>;
rail-name-loopA = "SOC";
rail-name-loopB = "CV";
status = "okay";
reserved-memory {
linux,cma {
status = "okay";
tegra_soc_hwpm {
status = "okay";
tegra-hsp@3d00000 {
status = "okay";
aon@c000000 {
status = "okay";
cpu_alert: cpu-throttle-alert {
status = "okay";
gpu_alert: gpu-throttle-alert {
status = "okay";
cv0_alert: cv0-throttle-alert {
status = "okay";
cv1_alert: cv1-throttle-alert {
status = "okay";
cv2_alert: cv2-throttle-alert {
status = "okay";
soc0_alert: soc0-throttle-alert {
status = "okay";
soc1_alert: soc1-throttle-alert {
status = "okay";
soc2_alert: soc2-throttle-alert {
status = "okay";
hot_surface_alert: hot-surface-alert {
status = "okay";
stm@24080000 {
status = "disabled";
cpu0_etm@27040000 {
cpu1_etm@27140000 {
cpu2_etm@27240000 {
cpu3_etm@27340000 {
cpu4_etm@27440000 {
cpu5_etm@27540000 {
cpu6_etm@27640000 {
cpu7_etm@27740000 {
cpu8_etm@27840000 {
cpu9_etm@27940000 {
cpu10_etm@27A40000 {
cpu11_etm@27B40000 {
funnel_ccplex0@26030000 {
funnel_ccplex1@26040000 {
funnel_ccplex2@26050000 {
funnel_top_ccplex@26020000 {
funnel_major@24040000 {
replicator@24060000 {
etf@24050000 {
etr@24070000 {
serial@31d0000 {
status = "okay";
mttcan@c310000 {
status = "okay";
mttcan@c320000 {
status = "okay";
spi1: spi@c260000 {
compatible = "nvidia,tegra186-spi-slave";
status = "okay";
tegra234-soc-spi.dtsi
Copyright (c) 2015-2021, NVIDIA CORPORATION. All rights reserved.
This program is free software; you can redistribute it and/or modify it
under the terms and conditions of the GNU General Public License,
version 2, as published by the Free Software Foundation.
This program is distributed in the hope it will be useful, but WITHOUT
more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/ .
aliases {
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
spi6 = &qspi0;
spi7 = &qspi1;
spi0: spi@3210000 {
compatible = "nvidia,tegra186-spi";
reg = <0x0 0x03210000 0x0 0x10000>;
interrupts = <0 36 0x04>;
#address-cells = <1>;
#size-cells = <0>;
iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
dma-coherent;
dmas = <&gpcdma 15>, <&gpcdma 15>;
dma-names = "rx", "tx";
spi-max-frequency = <65000000>;
nvidia,clk-parents = "pll_p", "clk_m";
clocks = <&bpmp_clks TEGRA234_CLK_SPI1>,
<&bpmp_clks TEGRA234_CLK_PLLP_OUT0>,
<&bpmp_clks TEGRA234_CLK_CLK_M>;
clock-names = "spi", "pll_p", "clk_m";
resets = <&bpmp_resets TEGRA234_RESET_SPI1>;
reset-names = "spi";
spi1: spi@c260000 {
reg = <0x0 0x0c260000 0x0 0x10000>;
interrupts = <0 37 0x04>;
#size-cells = <0>;
dma-coherent;
dmas = <&gpcdma 16>, <&gpcdma 16>;
nvidia,clk-parents = "pll_p", "osc";
clocks = <&bpmp_clks TEGRA234_CLK_SPI2>,
<&bpmp_clks TEGRA234_CLK_PLLAON>,
<&bpmp_clks TEGRA234_CLK_OSC>;
clock-names = "spi", "pll_p", "osc";
resets = <&bpmp_resets TEGRA234_RESET_SPI2>;
spi2: spi@3230000 {
reg = <0x0 0x03230000 0x0 0x10000>;
interrupts = <0 38 0x04>;
#size-cells = <0>;
dma-coherent;
dmas = <&gpcdma 17>, <&gpcdma 17>;
clocks = <&bpmp_clks TEGRA234_CLK_SPI3>,
resets = <&bpmp_resets TEGRA234_RESET_SPI3>;
qspi0: spi@3270000 {
compatible = "nvidia,tegra23x-qspi";
reg = <0x0 0x3270000 0x0 0x10000>;
interrupts = < 0 35 0x04 >;
#size-cells = <0>;
iommus = <&smmu_niso1 TEGRA_SID_NISO1_QSPI0>;
dma-coherent;
spi-max-frequency = <204000000>;
nvidia,clk-parents = "pllc", "pll_p";
clocks = <&bpmp_clks TEGRA234_CLK_QSPI0_2X_PM>,
<&bpmp_clks TEGRA234_CLK_QSPI0_PM>,
<&bpmp_clks TEGRA234_CLK_PLLC>,
<&bpmp_clks TEGRA234_CLK_PLLP_OUT0>;
clock-names = "qspi", "qspi_out", "pllc", "pll_p";
resets = <&bpmp_resets TEGRA234_RESET_QSPI0>;
reset-names = "qspi";
qspi1: spi@3300000 {
reg = <0x0 0x3300000 0x0 0x10000>;
interrupts = < 0 39 0x04 >;
#size-cells = <0>;
iommus = <&smmu_niso1 TEGRA_SID_NISO1_QSPI1>;
dma-coherent;
clocks = <&bpmp_clks TEGRA234_CLK_QSPI1_2X_PM>,
<&bpmp_clks TEGRA234_CLK_QSPI1_PM>,
resets = <&bpmp_resets TEGRA234_RESET_QSPI1>;
