On Kubernetes, `drop-frame-interval` Interval is not working for nvurisrcbin
• Hardware Platform (Jetson / GPU) GPU - T4
• DeepStream Version 6.1
• TensorRT Version - 8.2.5-1+cuda11.4
• NVIDIA GPU Driver Version (valid for GPU only) 525.105.17
• Issue Type( questions, new requirements, bugs) Bug
"I’m using the NVURISRCBIN as the source bin for a multi-stream setup. I have deployed the container on the Kubernetes POD. I have set the value for drop_frame_interval to 2, but it is not reducing the FPS to half. However, on the same configuration VM, it is able to reduce the FPS and is working fine.
The only difference in the code is nvbuf-memory-type. For the Kubernetes POD, I’m using the value 0, and for the internal VM, I’m using 3."
Here is inspect output for the nvstreammux
Which FPS are you referring to? The FPS from performance or somewhere else?
@yingliu ,
On the VM, despite the source stream running at 10 FPS, I can process it at 5 FPS output by setting the drop frame interval value to 2. However, the same configuration on the POD doesn’t yield the expected result; it continues processing at the source FPS, ignoring the drop frame interval set to 2.
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
could you test the latest DeepStream6.4? if DS6.4 still can’t work, which sample are you testing? what is the whole media pipeline? how did you test fps?
