On the AGX Orin platform (JP 6.0), occasionally when opening RGB capture, every frame reports an error with err_data = 512
In the camera application depicted in the diagram, we utilize GMSL for transmitting images to the SOC.
When using the AGX Orin platform with JetPack 6.0, occasionally encountering the “err_data = 512” error when attempting to open RGB, where each frame capture reports this error.
However, extensive testing with the same driver and device tree configuration on the AGX Xavier platform (JP 5.0.2) did not exhibit this issue.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Increase below in vi5_fops.c to try.
#define CAPTURE_TIMEOUT_MS 2500
Please also get the trace log to check.
vi5_fops.c has added define CAPTURE_TIMEOUT_MS 2500 .
This is the syslog where the issue occurred。
The on = 1 in the log for stream G2XX rgb 10-0066 indicates that it is enabled. on = 0 indicates that it is disabled.
syslog.txt (637.6 KB)
I mean increase the timeout like 5000.
Get the trace log.
https://elinux.org/Jetson/l4t/Camera_BringUp
ok,I try to increase the timeout and get a trace log
I attempted to change the timeout to 10000, but the RGB report still occasionally shows the error ‘err_data = 512’.
Trace log as follows
syslog.txt (1.2 MB)
Enable the trace log by below command.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 3 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Trace log as follows,Please analyze it, thank you.
trace.zip (1.4 MB)
The short frame error tell the output size doesn’t as driver reported.
     kworker/3:3-139     [003] ....  7056.680176: rtcpu_vinotify_event: tstamp:221286364907 cch:-1 vi:0 tag:CHANSEL_SHORT_FRAME channel:0xc1 frame:0 vi_tstamp:7081154912192 data:0x0000200001000000
Can you tell me what this log means?
rtcpu_vinotify_error: tstamp:223926929327 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:3 vi_tstamp:7165661714080 data:0x0000000000000001
The error tell the un-supported SPURIOUS data. Could be un-supported user define type data like below.
Table 1. MIPI Data Type IDs Supported by CX3
Data Type ID Name
0x00 Frame Start Code
0x01 Frame End Code
0x12 Embedded 8-bit non-Image Data
0x1E YUV422 8-bit
0x22 RGB565
0x23 RGB666
0x24 RGB888
0x2A RAW8
0x2B RAW10
0x2C RAW12
0x2D RAW14
0x30 User Defined 8-bit Data Type 1
0x31 User Defined 8-bit Data Type 2
0x32 User Defined 8-bit Data Type 3
0x33 User Defined 8-bit Data Type 4
0x34 User Defined 8-bit Data Type 5
0x35 User Defined 8-bit Data Type 6
0x36 User Defined 8-bit Data Type 7
0x37 User Defined 8-bit Data Type 8
