On the CloudXR4.0, when I left the device stationary for about half a minute, it was disconnected
I am certain that the pose are all sent over, but due to standing still, there is little change in pose.
this is log:
03-28 20:13:31.714 30305 30439 E CXR : E (netStreamClient) Disconnected by server with missing/malformed stopData of size 0
03-28 20:13:31.714 30305 30439 E CXR : E (Receiver) Receiver disconnected with error: 0X101.
03-28 20:13:31.714 30305 30439 E CXR : E (OVR Client) Server disconnected with error: The operation failed [cxrError_Failed]
03-28 20:13:31.714 30305 30336 E CXR : E (ReceiverXR) Receiver not streaming
03-28 20:13:31.714 30305 30336 E CXR : E (OVR Client) LatchFrame failed with error: The client is not streaming [cxrError_Not_Streaming]
I don’t believe you’re able to leave a connection perpetually suspended. @tegradave do you know if there’s a set timeout?
would want full server and client logs really to say for certain.
assuming you mean ‘left the device sitting idle on my desk for 30s’, it’s possible the device went into suspend mode, or it is possible the server side detected zero activity. Both sides would lead to a disconnect. Without full logs I couldn’t say which.
for the quest, I can’t remember if there is a developer option to have the device NOT sleep. from years ago, I’d just cover the sensor so it thinks it is still on head.
logs.zip (879.6 KB)
logs2.zip (1.4 MB)
@tegradave Here are two log files, each containing two complete logs.
Strange, I’m not seeing a specific cause in any message. But in the verbose logs it’s definitely a needle-in-a-haystack problem. :)
I’d expect logcat to have prints from the OS if it is going to sleep. Those may be buried in there somewhere. It looks like the client stops sending poses, and the server stops rendering, and eventually one end or the other declares end of session.
I am certain that the pose are all sent over, but due to standing still, there is little change in pose. You can see the TAG “jie”:
