In our carrier board, we can normally use Nano pin#118 CAM_AF_EN (GPIO3_PS.05) for DO(digit output), but when we use Xavier NX, we cannot control the same pin#118 GPIO01 (GPIO3_PQ.05). The GPIO01 is always high.
Nano pin#118 CAM_AF_EN (GPIO3_PS.05) pin mapping is gpio149
Xavier NX pin#118 GPIO01 (GPIO3_PQ.05) pin mapping is gpio421
gpiochip2: GPIOs 240-247, parent: platform/max77620-gpio, max77620-gpio, can sleep:
gpio-246 ( |gpio_default ) out hi
gpio-247 ( |gpio_default ) out hi
gpiochip1: GPIOs 248-287, parent: platform/c2f0000.gpio, tegra-gpio-aon:
gpio-253 ( |pex-refclk-sel-low ) out lo
gpio-266 ( |vdd-usb2-5v ) out hi
gpio-267 ( |i2c-mux-gpio ) out hi
gpio-268 ( |pwm-dimmer-enable ) out lo
gpio-284 ( |power-key ) in hi
gpiochip0: GPIOs 288-511, parent: platform/2200000.gpio, tegra-gpio:
gpio-289 ( |pcie-reg-enable ) out lo
gpio-336 ( |force-recovery ) in hi
gpio-338 ( |vdd-sdmmc1-sw ) out lo
gpio-339 ( |wifi-enable ) out hi
gpio-378 ( |pcie_wake ) in hi
gpio-385 ( |hdmi2.0_hpd ) in lo
gpio-390 ( |reset_gpio ) out lo
gpio-391 ( |bt_ext_wake ) out hi
gpio-392 ( |avdd-cam-2v8 ) out lo
gpio-412 ( |cam_reset_gpio ) out lo
gpio-413 ( |cam_reset_gpio ) out lo
gpio-425 ( |eqos_phy_reset ) out hi
gpio-480 ( |bt_host_wake ) in hi
gpio-489 ( |external-connection:) in hi
gpio-490 ( |pcie-reg-enable ) out hi
After export gpio421 :
gpio-421 ( |sysfs ) out lo
Our carrier board have two DO pins(pin#118 and pin#216),
pin#216 GPIO11 (GPIO3_PQ.06) can normally control but pin#118 cannot.
These two pins configuration are the same.
Can you give dump of this register 0x02430028?
Also, when you exported pin 421, it’s showing low, what voltage do you measure at this time?
It should be 0.
can you try toggling value and check voltage?
echo 1 > /sys/class/gpio/gpio421/value
***** Voltage here should be 3.3V
echo 0 > /sys/class/gpio/gpio421/value
***** Voltage here should be 0V
