There’s a typical argument that some people in the AI space make: that anything less than power-hungry data center hardware is the “wrong way” to run large models, and yet the Spark can run state-of-the-art (SotA) models perfectly well, at dramatically reduced space, noise, and power.
I decided to make this thread after yet another interaction with a user making such an argument, without justification, and without taking the time to consider the specific situations that people looking to run such clusters are operating under. Typically, this is a home or small office environment with one to several people who will use the cluster.
I’ve been on a journey to getting my 8x cluster of Sparks running and am now working on getting to a 16x cluster with dual CRS804 switches. My situation allows me to do this, while it wouldn’t allow me to do a conventional data center GPU deployment.
That’s a very different story than a “production” use case serving many, potentially millions of users, or a larger enterprise business wanting infrastructure that hundreds or thousands of employees use. Those are the use cases that the conventional data center hardware was built to serve. It serves them perfectly fine, yet trades off power efficiency, increases cooling requirements, and produces substantially more noise. It makes these tradeoffs for the sake of gaining much higher tokens per second, which is required if the situation calls for handling a large number of users simultaneously, but isn’t such a requirement otherwise.
A large Spark cluster makes sort of the reverse in terms of tradeoffs. It sacrifices insanely-fast TPS because that’s not a requirement in situations where there will be one or a few users and reasonable TPS will meet the needs. By doing so it gains the lower power usage, lower physical space requirements, and lower noise output that the Sparks have.
Another aspect of large Spark clusters that attracts the scrutiny of the enterprise-obsessed crowd is networking switches. It was fortunate that the Spark and the MikroTik CRS804 came out not too far apart. The CRS804 is the smallest, lowest power 4-port 400G switch on the market. In fact, there is no competitor to it at present. Yet many commenters insult the switch and even MikroTik as a company, all because the CRS804 doesn’t compare to much more expensive, physically larger, higher power usage, and noisier enterprise switches.
In the use cases that a large Spark cluster is solving, there’s nothing the CRS804 doesn’t offer, up to cluster sizes of 16. All of the benefits of an enterprise switch don’t provide any value at all in the home and small-office situations that a large Spark cluster is addressing. Yet people will push the use of an enterprise switch that only brings negatives to the table in the situations it’d be used in for a Spark cluster.
These attitudes are somewhat understandable. Setting debate over a bubble aside, the market has boomed and boomed hard. There’s been a lot of money made chasing the enterprise market. So people in that mindset see nails everywhere, with them offering the only hammers available. Luckily for us Spark fans, NVIDIA decided to release a mini PC and they decided to make it highly networkable by incorporating a ConnectX-7 NIC that offers 200Gbps networking. That’s what allows the unique positioning of the Sparks for large clusters to be reality.
TL;DR: Sparks are the de facto gold standard for running SotA models in a home or small-office setting. In fact, despite what some will throw around without further explanation, they’re currently the only usable way to do so in those settings. The MikroTik CRS804 is the de facto gold standard for doing the networking, up to 16 Sparks. Such a 16x cluster can run the full Kimi K3 model at usable speed on ~$100,000 worth of hardware (less if buying 2TB storage Sparks instead of 4TB) at ~2,000 watts of electricity. There’s no alternative currently available on the market or the horizon.
This thread is intended to be a place for talking about these points, countering incorrect points that put this configuration down, and for anyone who knows of a viable alternative to post detailed info on that alternative. We’d want to see proven ability to run SotA models within the unconventional, edge environments of a home or small office, so it’d need to not only run the model, but do so within reasonable bounds for space, noise, and power. The same goes for switches, with a viable alternative being a switch that clusters Sparks more cheaply than the CRS804 (it already saturates the bandwidth the Sparks can make use of) or a suitable switch that allows more than 16 Sparks to be clustered and information on why that’s desirable, such as a new, larger SotA model that couldn’t be run on a 16x cluster.
As an example, I’ll address the new M5 Ultra Mac Studio. It’s the closest competitor to a large Spark cluster, but it falls short in a few critical ways. It has less than half the networking speed at 80Gbps (this is everything for clustering), has a (currently) worse networking stack (Thunderbolt), has a less mature software stack that sees slower LLM speeds in practice, and is likely to be in lower availability than Sparks currently are. If anyone wants to present it as a contender, please show the above mentioned detailed info. It could be a reasonable competitor, but we’ll need to see that shown in the data. We want to avoid the norm of not providing any factual technical data that people throwing around suggestions to “just use something else” often act out. We want to avoid stating benefits that are disconnected from the home or small office use cases, such as benefits that only apply in conventional data center usage. We know what our problem is, self-hosting SotA LLMs in edge environments and we want the proposed solutions to be fit for that.
This community has been amazing. It’s amazing to go through the threads on this forum and see the work that’s played out over the past many months. It’s incredible that we’re at a time, just shy of four years since ChatGPT was launched, where we can run SotA LLMs at home. This is the future. We’re all helping to build it in real time by seeking the ability to run powerful AI locally. I can’t wait to enjoy the continued progress we’ll all see going forward!
