On the window I can see the results of the detection and also perform other operations, how should I do it in deepstream?
I should need a window that is full screen, but on the window I can see the results of the detection and also perform other operations, how should I do it in deepstream?
Using drm in deepstream, I can make the real-time detection results full screen, but usually I need other features besides the inference video of the detection. I should need a window that is full screen, but on which I can see the results of the detection and also perform other operations, such as: viewing the current map information of the vehicle, etc. This window comes with deepstream can be developed? Or do I need to embed the video in the window, is there any solution?
Do you mean you want to devlope a multiple windows app which including the DeepStream display window and the map window?
Under one window, both the live inference video window of deepstream and the map data information are displayed, while there may be other information displayed under this window.
Nowadays, only the real-time video of the reasoning results of deepstream is displayed in real time, which is monotonous for the user.
Are you talking about the UI design of your app?
I would like to discuss what kind of interface the nvdrmvideosink plugin in deepstream uses to throw out and how I should use this interface in win ui?
What kind of win ui does deepstream adapt to, and what do you recommend? Like qt.
nvdrmvideosink is DRM based.
If your windows UI compatible to DRM, it is OK.
