On which chip is IEP actually processed?
Software Version
DRIVE OS: 6.0.6.0
TensorRT: 8.5.10
CUDA: 11.4.20
CUDNN: 8.6.0
DRIVEWORKS: 5.10
NV_TA983SA
  1. On which chip is IEP actually processed?
  2. When I load sample application of nvm_iep_sci,it first prompts “NvRmGpuLibOpen failed, error=14”. The encoder instance id used in code is NVMEDIA_ENCODER_INSTANCE_AUTO.
If I execute command line: rmmod nvgpu, nvm_iep_sci runs successfully, but cpu load of 1 core is up to 90%. Why is cpu load so high?
Hozon Auto has the support contract with NV, please check with your internal team to know how to get the support via another channel. Thanks
