Capturing image from the onboard Jetson camera worked just fine with previous version of Jetpack 3.1 on TX2 using following lines of c code.
const string gst = "nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)24/1 ! nvvidconv flip-method=6 ! video/x-raw, format=(string)I420 ! videoconvert ! video/x-raw, format=(string)BGR ! appsink";
VideoCapture cap(gst); // open the default camera
However this same code fail to open camera with Jetpack 3.2 clean install.
When tried to run
gst-launch-1.0 nvcamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1280, height=720, framerate=30/1, format=NV12' ! nvoverlaysink -ev
The camera works in full screen mode and in terminal I get
Setting pipeline to PAUSED ...
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 1 WxH = 2592x1458 FrameRate = 30.000000 ...
/GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)NV12\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)NV12\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)NV12\,\ framerate\=\(fraction\)30/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ format\=\(string\)NV12\,\ framerate\=\(fraction\)30/1"
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:03.751757536
Then what string value should be entered to open the camera?
Thanks,
