We are developing a camera sensor with one-lane. We are unable to run v4l2-ctl successfully with the following command:
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3
dmesg contains the following:
[ 24.664081] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_200M
[ 24.664087] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_300M
[ 143.055509] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 144.059429] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 145.063488] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 146.067565] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 147.071699] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 148.075842] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 149.079866] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[ 149.089642] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x00000004
[ 149.098554] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x0001000e
[ 149.106468] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x0001000e
We would like to know what the values for INTR_STATUS, ERROR_STATUS2VI_VC0, and ERR_INTR_STATUS are and if there is some header file you can share with a list of all the possible error values.
