I’ve replaced the SSD in an SN2410 switch. Embedded ONIE and now trying to install Onyx. But it fails with this error:
=== Writing partition table to DISK1
Error: You requested a partition from 256MiB to 448MiB (sectors 524288…917503).
The closest location we can manage is 385MiB to 448MiB (sectors 788480…917503).
Error: Partition doesn’t exist.
== Creating ext3 filesystem on /dev/sda10 for VAR
mke2fs: No such device or address while trying to determine filesystem size
*** Could not make filesystem on /dev/sda10
== Cleanup
====== Ending image install with error at 20210827-124209
Error: writeimage failed, exiting.
====== Ending image manufacture with error at 20210827-124209
Error: failed running /etc/init.d/rcS.d/S10tms_dhcpc
Running /etc/init.d/rcS.d/S30tms_autostart
Any idea what this might be? Looks to me it’s trying to create partitions too large that it won’t fit on the disk?
Full output:
Manufacture script starting
== Using model: x86onie
== Using kernel type: smp
== System disk size: 60 GB
== Using layout: X86ONIE_32GB
== Using partition name-size list:
== Using device list: /dev/sda
== Using interface list: mgmts0 mgmts1
== Using interface naming: ifindex-sorted
== Smartd disabled
== Cluster enable: no
== Cluster ID: (none)
== Cluster description: (none)
== Cluster interface: (none)
== Cluster master virtual IP address: 0.0.0.0
== Cluster master virtual IP masklen: 0
== Cluster shared secret: (none)
== Cluster expected number of nodes: 0
- Assigning specified interface names in ifindex-sorted order
– Mapping MAC: ec:0d:9a:7d:b6:86 from: eth0 to: mgmts0
– Mapping MAC: ec:0d:9a:7d:b6:87 from: eth1 to: mgmts1
== Using image from file: /hd-media/image-X86_64-3.8.2204.img
== Calling writeimage to image system
— Executing: /sbin/writeimage.sh -m -I -f /hd-media/image-X86_64-3.8.2204.img -v -k smp -L X86ONIE_32GB -d /dev/sda
====== Starting image install at 20210827-124005
==== Manufacturing image
==== Using layout: X86ONIE_32GB
==== Layout targets: DISK1
==== Using devices: /dev/sda
==== Using bootmgr: grub2
==== Hardware name: X86_64
==== Verifying no needed partitions currently mounted
==== Verifying targets can be repartitioned
[ 16.608646] sda: sda1 sda2
==== Verifying MTD partitions are the correct size
==== Verifying targets are big enough
==== Target change list: DISK1
== Free RAM: 7132MB.
== Ramdisk 3072MB for image extraction will be used.
==== Mounting tmpfs for working area
==== Tmpfs size used: 3072M
==== Copying image file from /hd-media/image-X86_64-3.8.2204.img
==== Verifying image integrity for image-X86_64-3.8.2204.img
Unpacked directory is /tmp/mnt_image_wi/tmpfs/unzip
Verifying hashes
Done
== Running version: X86_64 3.8.2204 2019-12-29 16:11:11 x86_64
== Image version: X86_64 3.8.2204 2019-12-29 16:11:11 x86_64
== Image size: 659 MB / 1755 MB uncompressed
==== Uncompressing source image file: /tmp/mnt_image_wi/tmpfs/unzip/image-X86_64-x86_64-x86_64-20191229-161111.tbz to /tmp/mnt_image_wi/tmpfs/unzip/image-X86_64-3.8.2204.tar
==== Disk partitioning
=== Calculating gpt partition table for DISK1
== Device size: 57241 M
== Allocated fixed size: 30104 M
== Unallocated by fixed: 27073 M
== Unallocated after growth: 27137 M
Model: ATA SFSA060GU4AA2TO- (scsi)
Disk /dev/sda: 57242MiB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1.00MiB 257MiB 256MiB fat16 EFI System boot, hidden
2 257MiB 385MiB 128MiB ext4 ONIE-BOOT hidden
Disk Flags:
3 448MiB 640MiB 192MiB ext3 primary
4 640MiB 832MiB 192MiB ext3 primary
5 832MiB 3904MiB 3072MiB ext3 primary
6 3904MiB 6976MiB 3072MiB ext3 primary
7 6976MiB 7168MiB 192MiB ext3 primary
8 7168MiB 7360MiB 192MiB ext3 primary
9 7360MiB 57242MiB 49882MiB ext3 primary
==== Making filesystems
Partprobe
/dev/sda: gpt partitions 1 2 3 4 5 6 7 8 9
== Creating ext3 filesystem on /dev/sda4 for BOOT1
== Creating ext3 filesystem on /dev/sda5 for BOOT2
== Creating ext3 filesystem on /dev/sda3 for BOOTMGR
== Creating ext3 filesystem on /dev/sda8 for CONFIG
== Creating ext3 filesystem on /dev/sda9 for OUTPUT
[ 132.443719] random: crng init done
== Creating ext3 filesystem on /dev/sda6 for ROOT1
== Creating ext3 filesystem on /dev/sda7 for ROOT2
== Cleanup
(none) login:
