Hello there,
(my laptop has rtx 2060 and intel gpu)
When I first installed Manjaro there were nouveau drivers. I deleted it due to both high power consumption and annoying sound and heating problems. Instead, I installed nvidia’s own drivers from the panel. This time the power consumption was back to normal but my external screen was a bit lagging and there was screen flickering. I open Nvidia X settings and
there is some missing settings. I tried to open it from terminal;
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions."
After that I implemented the solution from this article;
https://wiki.manjaro.org/index.php/Simple_fix_for_screen_tearing_-_nVidia
Now my external display lagging problem has been resolved. In terms of performance, the computer is in good condition, but the laptop screen remained black.
(you can see AOC is my external monitor and X screen 0 is laptop screen)
and sometimes it freeze and i can’t do anything. I can’t get tty either
Here is some outputs;
> ~ inxi --full --admin --verbosity=3 --filter --no-host ✔
System:
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
root=UUID=33b8271b-15b5-4c38-acce-c334f003a8ea rw quiet splash apparmor=1
security=apparmor udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Laptop System: Micro-Star product: GS66 Stealth 10SE v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16V1 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16V1IMS.112 date: 11/19/2020
Battery:
ID-1: BAT1 charge: 97.4 Wh (100.0%) condition: 97.4/95.0 Wh (102.5%)
volts: 17.3 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Full
CPU:
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E2
cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 62431
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 801
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel UHD Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:6
chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Audio:
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:7
chip-ID: 0d8c:0012 class-ID: 0300
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network:
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlo1 state: up mac: <filter>
Device-2: Intel driver: igc v: kernel port: 3000 bus-ID: 3c:00.0
chip-ID: 8086:3101 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:8
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Drives:
Local Storage: total: 476.94 GiB used: 12.28 GiB (2.6%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 21111000 temp: 40.9 C scheme: GPT
Partition:
ID-1: / raw-size: 190.94 GiB size: 186.88 GiB (97.88%)
used: 12.25 GiB (6.6%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 37.6 MiB (39.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Swap:
Alert: No swap data was found.
Sensors:
System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A
Info:
Processes: 282 Uptime: 14m wakeups: 1 Memory: 15.46 GiB
used: 1.16 GiB (7.5%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1202 lib: 299 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-linux 2018.05.04 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
Warning: No installed USB configs!
inxi -G
Graphics: Device-1: Intel UHD Graphics driver: i915 v: kernel
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] driver: nvidia v: 465.31
Display: x11 server: X.org 1.20.11 driver: loaded: nvidia
If you want additional command output I will send it quickly. Thank you
