Only external monitor in sync list
i have a notbook, 9750H and GTX2060
internal monitor is 1080p 144Hz, and external monitor is 1440p 75Hz
but now, i cannot use 144hz sync in both monitor… all applications lock to 75Hz…
xorg.conf
Debian Testing 5.18
515.65.01
Please post the output of
sudo cat /sys/module/nvidia_drm/parameters/modeset
it said Y
Thank you!
and this is my nvidia-bug-report.sh
nvidia-bug-report.log.gz (279.3 KB)
any help?
Not really. Does it work if you switch to render offload mode?
what’s “render offload mode”…? and how i can i swith to?
If i disable externl moniitor, use laptop internal screen, vsync can archieve to 144Hz
Render offload:
https://download.nvidia.com/XFree86/Linux-x86_64/495.44/README/primerenderoffload.html
Basically, your complete xorg.conf can be replace by a simple
/etc/X11/xorg.conf.d/12-nvidia-prime.conf
Section "OutputClass"
    Identifier     "nvidia"
    MatchDriver    "nvidia-drm"
    Driver         "nvidia"
    Option "PrimaryGpu" "true"
EndSection
For render offload, comment out the primarygpu option
    Identifier     "nvidia"
    Driver         "nvidia"
    #Option "PrimaryGpu" "true"
EndSection
external monitors can then be eabled by running
xrandr --setprovideroutputsource NVIDIA-G0 modesetting
and applications be run on the nvidia gpu by prepending
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia
e.g.
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxgears
