I installed CUDA 8.0 toolikit through deb file,
but there is no ‘bin’ file in /usr/local/cuda-8.0, only ‘extras’ file exists.
I followed installation guide as far as I know.
Could anybody help me out?
Env: ubuntu 16.04, gtx1080
Ubuntu 17.04 is not officially supported by any current version of CUDA, and in particular you’re going to have trouble with the C compiler. Also, CUDA 8.0.44 is not the recommended CUDA 8 version anymore.
Get your cuda installers from here:
[url]http://www.nvidia.com/getcuda[/url]
Follow the install instructions (carefully!) in the linux install guide:
the login loop is a problem not unique to Ubuntu 17.
If you search on ubuntu cuda login loop, you’ll find instructions for how to avoid it (including various writeups on this forum)
for example:
when you install cuda more than one time,you must use :
sudo rm -rf /usr/local/cuda*
sudo apt-get remove cuda-*
to uninstall the original cuda
same here. have you solved the problem?
