Only secondary display functioning after generating xorg.conf for Nvidia
I am running Pop!_OS on a laptop with an onboard Nvidia GPU. As usual, my secondary monitor has screen tearing issues with Nvidia linux drivers. This is fixed by enable Force Full Composition Pipeline. I added the following lines to my xorg.conf.
Option         "nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
Option         "AllowIndirectGLXProtocal" "off"
Option         "TripleBuffer" "on"
Upon rebooting, only my second monitor (but primary display), connected through HDMI, is functioning. I think this may be related to my laptop display being a PRIME display. I believe even manually saving any sort of xorg.conf from nvidia server settings results in this problem. So, why does this issue only occur if a have a xorg.conf generated?
This is my entire xorg.conf file:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 440.82
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "VIZ E241-A1"
    HorizSync       30.0 - 70.0
    VertRefresh     58.0 - 76.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 1060"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
nvidia-bug-report.log.gz (493.6 KB)
Thanks,
please include the nvidia-bug-report log file…
as root, run
$ nvidia-bug-report.sh
attach the log files here…
maybe somebody will examine the log and figure out what is happening
It is now attached at the bottom. Thanks for the advice
Your installation looks okay for me… try to disabled nouveau and put the busid on xorg.conf and enable intel for your prime display…
Blacklisting nouveau
echo “blacklist nouveau” >> /etc/modprobe.d/blacklist.conf
Edit the /etc/X11/xorg.conf
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Monitor"
    Identifier     "Monitor1"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BusID          "PCI:1@0:0:0"
EndSection
Section "Device"
    Identifier     "Device1"
    Driver         "intel"
    VendorName     "INTEL Corporation"
    BoardName      "HD Graphics 630"
    BusID          "PCI:0@0:2:0"
EndSection
Section "Screen"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
EndSection
Section "Screen"
    Identifier     "Screen1"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
