• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi this is my config file, I need help with the parser bbox function, and custom-lib-path for onnx::
ERROR: [TRT]: ModelImporter.cpp:777: ERROR: ModelImporter.cpp:547 In function importModel:
[4] Assertion failed: !mImporterCtx.network()->hasImplicitBatchDimension() && “This version of the ONNX parser only supports TensorRT INetworkDefinitions with an explicit batch dimension. Please ensure the network was created using the EXPLICIT_BATCH NetworkDefinitionCreationFlag.”
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:315 Failed to parse onnx file
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:971 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:804 failed to build network.
• TensorRT Version
• The pipeline being used
This is my detector model config trained using yolo, and this is my config:
SPDX-FileCopyrightText: Copyright (c) 2019-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
SPDX-License-Identifier: Apache-2.0
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
I am looking for onnx config, parameters
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.4/DeepStream-Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
these 3 variables, what should be the respective values, if I am using a ONNX file.
