I am getting am error while building the wheels for ONNX file. If someone could solve it that will be great.
docky4gb@docky4gb-desktop:~$ pip3 install onnxruntime_gpu-1.8.0-cp36-cp36m-linux_aarch64.whl
Defaulting to user installation because normal site-packages is not writeable
Processing ./onnxruntime_gpu-1.8.0-cp36-cp36m-linux_aarch64.whl
ERROR: Exception:
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/base_command.py”, line 180, in _main
status = self.run(options, args)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/req_command.py”, line 204, in wrapper
return func(self, options, args)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/commands/install.py”, line 319, in run
reqs, check_supported_wheels=not options.target_dir
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/resolver.py”, line 104, in resolve
req, requested_extras=()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/factory.py”, line 434, in make_requirement_from_install_req
version=None,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/factory.py”, line 205, in _make_candidate_from_link
version=version,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 312, in init
version=version,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 151, in init
self.dist = self._prepare()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 234, in _prepare
dist = self._prepare_distribution()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 318, in _prepare_distribution
self._ireq, parallel_builds=True
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 508, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 571, in _prepare_linked_requirement
req, self.req_tracker, self.finder, self.build_isolation,
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/operations/prepare.py”, line 61, in _get_prepared_distribution
return abstract_dist.get_pkg_resources_distribution()
File “/usr/local/lib/python3.6/dist-packages/pip/_internal/distributions/wheel.py”, line 27, in get_pkg_resources_distribution
with ZipFile(self.req.local_file_path, allowZip64=True) as z:
File “/usr/lib/python3.6/zipfile.py”, line 1131, in init
self._RealGetContents()
File “/usr/lib/python3.6/zipfile.py”, line 1198, in _RealGetContents
raise BadZipFile(“File is not a zip file”)
zipfile.BadZipFile: File is not a zip file
And also can someone send me a clean tutorial of how to convert my existing Tensorflow yolov4-tiny model to Tensort and Deepstream, all the tutorials available are for example codes of NVIDIA and no tutorial is there for starting it from zero.
