Hello!
I’ve been working on training trafficcamnet on my own dataset of images with only cars using TAO train. After the model has been trained, instead of using TAO inference, I want to conduct inference in python with an exported onnx model. I’ve created post-processing code but when I run debug images through my post-processor they do not match the detections I am seeing in clearml bbox_preds. The coordinates of the detections are off by about 10 pixels in both x and y dimensions. This is before I run the detections through a clustering algo like NMS or DBSCAN.
To create my post-processor I’ve dug through the [tao_tensorflow_backend] (https://github.com/NVIDIA/tao_tensorflow1_backend/tree/main/nvidia_tao_tf1/cv/detectnet_v2/postprocessor) repository. Here is my code:
class TrafficCamNetPostProcess(object):
def __init__(self, width, height, score=0.15, classes=[0]):
Params:
width,height(int) is the image-size that you want to get the BBX
score(float) is the confidence
classes(int-list) is the 3-classes(0 for person,1 for bag, 2 for face)
self.image_width = width
self.image_height = height
self.model_h = 544
self.model_w = 960
self.stride = 16.0
self.box_norm = 35.0
self.grid_h = int(self.model_h / self.stride)
self.grid_w = int(self.model_w / self.stride)
self.grid_size = self.grid_h * self.grid_w
self.grid_centers_w = []
self.grid_centers_h = []
for i in range(self.grid_h):
value = (i * self.stride + 0.5) / self.box_norm
self.grid_centers_h.append(value)
for i in range(self.grid_w):
self.grid_centers_w.append(value)
min_confidence (float): min confidence to accept detection
analysis_classes (list of int): indices of the classes to consider
self.min_confidence = score
self.analysis_classes = classes
def applyBoxNorm(self, o1, o2, o3, o4, x, y):
Applies the GridNet box normalization
Args:
o1 (float): first argument of the result
o2 (float): second argument of the result
o3 (float): third argument of the result
o4 (float): fourth argument of the result
x: row index on the grid
y: column index on the grid
Returns:
float: rescaled first argument
float: rescaled second argument
float: rescaled third argument
float: rescaled fourth argument
o1 = (o1 - self.grid_centers_w[x]) * -self.box_norm
o2 = (o2 - self.grid_centers_h[y]) * -self.box_norm
o3 = (o3 + self.grid_centers_w[x]) * self.box_norm
o4 = (o4 + self.grid_centers_h[y]) * self.box_norm
return o1, o2, o3, o4
def change_model_size_to_real(self, model_size, type):
real_size = 0
if type == 'x':
real_size = (model_size / float(self.model_w)) * self.image_width
elif type == 'y':
real_size = (model_size / float(self.model_h)) * self.image_height
real_size = int(real_size)
return real_size
def start(self, buffer_bbox, buffer_scores):
Postprocesses the inference output
Args:
outputs (list of float): inference output
Returns: list of list tuple: each element is a two list tuple (x, y) representing the corners of a bb
bbs = []
for c in range(3):
if c not in self.analysis_classes:
continue
x1_idx = (c * 4 * self.grid_size)
y1_idx = x1_idx + self.grid_size
x2_idx = y1_idx + self.grid_size
y2_idx = x2_idx + self.grid_size
boxes = buffer_bbox
for h in range(self.grid_h):
for w in range(self.grid_w):
i = w + h * self.grid_w
score = buffer_scores[c * self.grid_size + i]
if score >= self.min_confidence:
o1 = boxes[x1_idx + w + h * self.grid_w]
o2 = boxes[y1_idx + w + h * self.grid_w]
o3 = boxes[x2_idx + w + h * self.grid_w]
o4 = boxes[y2_idx + w + h * self.grid_w]
o1, o2, o3, o4 = self.applyBoxNorm(
o1, o2, o3, o4, w, h)
xmin_model = int(o1)
ymin_model = int(o2)
xmax_model = int(o3)
ymax_model = int(o4)
xmin_image = self.change_model_size_to_real(
xmin_model, 'x')
ymin_image = self.change_model_size_to_real(
ymin_model, 'y')
xmax_image = self.change_model_size_to_real(
xmax_model, 'x')
ymax_image = self.change_model_size_to_real(
ymax_model, 'y')
rect = (xmin_image, ymin_image, xmax_image, ymax_image)
bbs.append(rect)
return bbs
Here is how one of the test images looks in clearml,
When I run it through onnx inference and my post processor like this:
results = onnx_infer(image_np, ort_session)
bboxs = results[0].flatten()
scores = results[1].flatten()
trafficcamnet_postprocess = TrafficCamNetPostProcess(model_w, model_h, score=0.001, classes=[0], pad = 15)
rects = trafficcamnet_postprocess.start(bboxs, scores)
I get a result which looks like this:
I thought some background pre-processing during TAO training could be causing this offset, so I eliminated translate_max_y and translate_max_x in my training config. Here is my augmentation_config and postprocessing_config.
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 0.0
translate_max_y: 0.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "car"
value {
clustering_config {
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.1
coverage_threshold: 0.001
dbscan_eps: 0.15
dbscan_min_samples: 1
minimum_bounding_box_height: 20
Any idea why I am seeing this offset? Thanks!
